Old 10-26-2019, 08:18 PM   #1
Chevy Fleetside
Chevy Fleetside's Avatar
Rebuilding Engine
I figured it was time to rebuild the engine in my truck as it was leaking and burning a lot of oil, not to mention some knocking sounds. It is at the machine shop right now. I was trying to get engine color. I thought it was the green color but come to find it is the blue/gray color. Here are some pictures for you enjoyment as I know you guys like pictures. I will have some after pictures when the time comes. There was no bearing material on the rods except for the #4 hole. I could use the lifters at bowls.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-26-2019, 08:21 PM   #2
Chevy Fleetside
Re: Rebuilding Engine
More. If anyone knows where I can get the engine color I would love for you to pass that info along to me. As it is I am going to take the oil pan with me to the paint store and see what they can do.
Old 10-26-2019, 09:07 PM   #3
SkinnyG
SkinnyG's Avatar
Consider springing for a retrofit roller cam. Pricey, but you don't need to stress over the level of zinc/zddp in your oil.
I haven't yet found what the proper color is, though I understand many use Ford Gray (which is what I used on the motor in my '61).
If you can polish up some of the original color, you can probably have your local paint shop match it.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 10-26-2019, 10:35 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Looks like you got your money's worth out of that bad boy! Those lifters don't have holes in the bottoms, in spite of that amount of dishing. Amazing.
~Steven
Simi Valley, CA
Old 10-26-2019, 10:55 PM   #5
AcampoDave
AcampoDave's Avatar
Here's what they look like in Ford gray. I also went with a gloss clear over the gray which was also made for engines.
AcampoDave is offline   Reply With Quote
Old 10-26-2019, 11:39 PM   #6
Getter-Done
Getter-Done's Avatar
Here is an interesting article about the paint color story.
Looks like they may sell paint that is a close match.
Link:https://www.fillingstation.com/articles/grayengine.htm
The early bird gets the worm,
84 Chevy K-20
Old 10-27-2019, 03:10 AM   #7
Mike1965
Mike1965's Avatar
I used this paint https://www.hirschauto.com/ENGINE-EN...RT/CHV%20GREY/ for my 283 in my 65' C20, it looks better in person than the picture. It is a close match to the original.
Mike1965 is offline   Reply With Quote
Old 10-27-2019, 10:09 AM   #8
Chevy Fleetside
I am guessing it is the Chevrolet gray 29-52. The link brings up all the color choices.
Old 10-27-2019, 10:19 AM   #9
Chevy Fleetside
You should see the Cam.
Old 10-27-2019, 12:44 PM   #10
jayoldschool
Moderator
Looking at that timing setup... this thing skipped a few oil changes over its life...
jayoldschool is offline   Reply With Quote
Old 10-27-2019, 01:12 PM   #11
Chevy Fleetside
Just a few. I have had it for I believe 4 years now. Mileage unknown. Speedo broke at 54999.
Old 10-27-2019, 02:39 PM   #12
Mike1965
Mike1965's Avatar
Yup that's the color I used and it looks really nice.
Old 10-27-2019, 03:20 PM   #13
vince1
Did that speedometer break at 154999 or 254999?
That is more worn out than I have ever seen before.
vince1 is offline   Reply With Quote
Old 10-27-2019, 11:13 PM   #14
Chevy Fleetside
I don't really know.
Old 10-28-2019, 09:10 AM   #15
60-66
60-66's Avatar
That's a MUCH closer color to the factory grey , than the Ford color. Looks great !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 10-28-2019, 01:42 PM   #16
Mike1965
Mike1965's Avatar
Thanks! I've been meaning to make a build thread on the truck that engine is going in. Glad you like the color, it looks way better in person.
Old 10-29-2019, 12:21 PM   #17
Chevy Fleetside
I stopped by an autobody paint store yesterday and found a close match to my oil pan color. I will post pictures after I paint. That would be in about a week or 2.
Old 10-30-2019, 06:04 AM   #18
G8rN@te61
I assume a quart was enough to cover your engine?
G8rN@te61 is offline   Reply With Quote
Old 11-03-2019, 09:30 PM   #19
Chevy Fleetside
I just bought one arousal can. Should be enough as long as I don't waste it. If I want to do a separate quart with hardener, it will be $101.
Old 11-03-2019, 10:43 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
I think that it will take two cans. In my experience, one won't quite make it. BUT, the gray may be a real high-hide color, and it may only take one can. I know that the Moly Orange usually took a little less than two cans to cover a V-8 engine. Maybe I was just happy with the fumes?
~Steven
Simi Valley, CA
Old 11-04-2019, 12:43 AM   #21
Chevy Fleetside
I bought one just in case I didn't like the color. I will be using black Epoxy Primer so that will help a lot.
Old 11-11-2019, 02:52 PM   #22
Chevy Fleetside
Got my short block back. A friend has a set of heads already done but I'm still waiting for them. My other dilemma is whether to put a 700r4 automatic transmission I have or back to the 3 on the tree which is also an overdrive but not original to the truck. With an auto my son could drive it but I do plan on teaching him how to drive a stick.
Old 11-11-2019, 04:29 PM   #23
geezer#99
geezer#99's Avatar
Nice shiny parts!
What heads are you gonna use?
What valve sizes?
How many CC’s?
geezer#99 is online now   Reply With Quote
Old 11-11-2019, 06:20 PM   #24
Chevy Fleetside
stock 283 heads. Not looking for a lot of HP just a nice running truck.
Old 11-11-2019, 06:32 PM   #25
geezer#99
geezer#99's Avatar
All is good!
Just curious!
Some people bolt on higher cc heads without a thought and loose a bunch of compression and power.
