![]() Join Date: Aug 2018
1978 Chevy Scottsdale K20 Camper Special
1978 Chevy K20 Camper Special
350/TH400/NP203 Odometer shows 19,xxx but true mileage unknown. Dana 44 front/Full float 14 bolt rear New wheels and tires Runs and shifts well Just did a tuneup (plugs, wires, intake gasket, set timing, replaced fuel pump) Front brakes rebuilt-rotors, pads, calipers, hoses, wheel bearings New front driveshaft New interior (dash pad, gauge bezel, bluetooth radio, front & rear speakers, flooring, seat foam & cover, door panels, heater core, headlight switch, turn signal switch, instrument cluster circuit board) New window regulators, mirrors, grille, all new bulbs and lenses Very little body rust. Some bubbling at wheel openings and some rust under battery tray but is a solid truck. This truck is geared pretty low - probably 4.10 in the rear and 55 MPH is about the max. Fuel gauge does not work - probably needs new sending units. Could also use carb adjustment or rebuild. Asking $7,500. Located in Grand Junction, CO. Can provide more photos upon request.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax Last edited by MDPotter; 04-06-2023 at 09:52 AM. |
Re: 1978 Chevy Scottsdale K20 Camper Special
Good afternoon,
Is this truck still available? Greg in Missouri |
Yes it is. Just replaced both sending units and driver side tank. Needs a new speedometer cable.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
