Old 12-16-2003, 02:20 PM   #1
Slammed67
Progress = 0%
Slammed67's Avatar
Arrow Jim Meyer '60-87 GM Pickup IFS
Anyone see the tech article in the current Classic Trucks Magazine regarding the Jim Meyer bolt-in IFS? Looks like a nice (and complete) kit. Those of you who are interested in a lowered stance/rack and pinion steering/disc brakes might want to check it out. There was no price given in the magazine, but I'm sure it's not cheap.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-16-2003, 03:57 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Last time I heard it was right around $1200 or so.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-17-2003, 11:58 AM   #3
SCOTI
SCOTI's Avatar
It looks like a decent set-up. The one thing I didn't like was the upper arms use teflon coated spherical bearings which my guess is will either wear rapidly or squeek alot w/a lot of miles.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2003, 03:31 AM   #4
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
Yeah I read it, it is a a nice setup well designed and uses factory calipers and rotors. And for that base price I would go that route before I notched a crossmember and bought drop spindles the ease and simplicity would be worth it to me. I plan on buying one with shockwaves for my 65 in the verry distant future, if I can ever finish my panel and school.
GMC JUNKIE TOO is offline   Reply With Quote
Old 12-18-2003, 10:55 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally posted by GMC JUNKIE TOO
..... I plan on buying one with shockwaves for my 65 in the verry distant future, if I can ever finish my panel and school.
Are you planning on driving it on the street? You might want to reconsider the Shockwaves. On most systems, the best you can get is 4 to 5" of lift "max". That's not much if you are starting off on the ground. Since you don't want to drive with them "maxed" out, you are talking about less than 4" of usable lift...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-18-2003, 01:22 PM   #6
Izzy
Trucker.
Izzy's Avatar
I would personally rather wait for ART to come out with their tubular UCA/LCA’s(bag ready) and notch the stock crossmember.
Izzy is offline   Reply With Quote
Old 12-18-2003, 01:36 PM   #7
grnddwn
belly dragger
grnddwn's Avatar
I only drive at about 3" off the ground so 4" of lift isn't that bad except it might ride a little stiff
grnddwn is offline   Reply With Quote
Old 12-22-2003, 05:04 PM   #8
bagged87chevy
bagged87chevy's Avatar
how much of a crossmember drop is this kit? Will it set the frame on the ground? Any body reccomend this over turners kit?
I want my truck done!
bagged87chevy is offline   Reply With Quote
Old 12-22-2003, 11:47 PM   #9
GMC JUNKIE TOO
With this kit you dont use any of your original parts. It has a new crossmember, control arms, spindles rack and pinion steering parts to hook it up, rotors and calipers and built in motor mounts I would definatley go with this setup over turners. I am allso looking at a kit from scott's.
Old 12-23-2003, 10:36 AM   #10
SCOTI
SCOTI's Avatar
The biggest question is how much difference in ground clearance does each set-up offer?
What would be good to compare is the distance between the lowest part of the crossmember to the bottom of the frame rail @ spindle C/L on a stock set-up vs. Turners, & J.Meyers.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-23-2003, 03:35 PM   #11
bagged87chevy
Thats what I was talking about which one would give you more clearance Turners or jim meyers. If jims's kit offers the same amount of clearance it looks to me like it would make since to go with it because of how complete it is.
Old 01-16-2004, 09:51 PM   #12
GMCGRANDS
Jim Meyers is one of the nicest front ends ive seen. All bolt on, zero bump steer, Adjustable ride height,and GM based rather than Mustang II, other than the rack. It uses Impalla/ caprice rotors and spindles. The only drawback is the price $3200.00 with the coil overs, Shockwaves are even more! Even the stage one kit with no spindles, rotors, or rack is $2600.00
Mark
72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction
05' GMC Sierra Denali LQ9
GMCGRANDS is offline   Reply With Quote
