Old 12-11-2023, 10:54 PM   #1
jeff74
jeff74's Avatar
Low dollar distributor tester
I came across an article about building your own distributor tester.. "Build your own distributor test machine for under $100" by Joe Randolph
Seems like a neat idea and I have everything on hand except for a pwm motor controller, which I ordered from ebay for about $15. The first picture is a test of the fan motor from my truck , using a cheap digital tach I had bought to use with my lathe, but haven't mounted yet. I just taped the magnet to the 'coupler'(piece of heater hose) to try it out. It's pretty steady right around 3000rpm
Second picture is a few other parts, a degree wheel that I printed and glued to a piece of thin cardboard , a toasted honda timing gear that will be the hub for the wheel, and an old oil pump shaft to drive the distributor. I had to open up the timing gear slightly on the lathe to be a nice fit on the bottom of the distributor gear.
I'll build the stand this week, for now it will just be 2x4's. I also have a coil and some old spark plug leads around here. The truck is mostly parked for the winter so it'll be cool to get the distributor all set up.
1971 GMC C25 with a 'refreshed' 1996 Vortec 350/SM465
jeff74 is offline   Reply With Quote
