Old 12-24-2023, 11:48 AM   #1
Dan-K
Carrier bearing insulator ?
Has anyone ever put a thin piece of rubber between the carrier bearing where it mounts to the frame ? Cant see where this would hurt anything and may cut down vibration etc. Your thoughts ?
Dan-K is offline   Reply With Quote
Old 12-24-2023, 01:21 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Carrier bearing insulator ?
I think that re-balancing the driveshaft would be a better option, if there is vibration from it. It already has a neoprene doughnut between the bearing and the pedestal mount.
~Steven
Simi Valley, CA
Old 12-24-2023, 02:34 PM   #3
HO455
HO455's Avatar
If the drive shaft components are in good shape and the U-joint angles in specification there should be no noticeable vibration.
You may end up causing problems down the road if the rubber allows the carrier to move around under high load conditions.
In today's vehicles with NVH being a priority I've not seen any OE rubber mount the carrier bearing. The rubber bushing in the carrier bearing is supposed to absorb normal vibration.
RIP Bob Parks.
Old 12-24-2023, 09:55 PM   #4
425HP409
425hp409
425HP409's Avatar
For those of you that use a center carrier with a 2 piece small block driveshaft, showcars.com has one with a polyurethane bushing. It is their part #6668.it fits cars 58-64 and trucks with a 2 piece driveshaft, except some big blocks. I had a problem with vibration on hard acceleration on a 63 Impala with a 327. The #6668 fixed it.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
