![]() Join Date: Nov 2001
Bolt size help needed for 67-68 Grille Support- Center
There are two small bolts that hold the grille center support, one each for the back of the top and bottom inserts of the grill, along with u-nuts they screw into. Mine were rusted and cut out, must of swept them up with the pile of rust . I looked through some catalogs with no luck. Happy New Year
Thanks NGN Nick |
![]() Join Date: Dec 1999
Re: Bolt size help needed for 67-68 Grille Support- Center
I thought I had the sizes written down, but I only found this picture...Maybe this helps.
I went to pull one out of my truck and found I didn't put them back. Found them in stuff I had plated.
#14 x 5/8 Like these - https://www.auveco.com/14-x-5-8-ind-...crew-zinc-2370 I think the j-nuts would be - https://www.auveco.com/j-nuts/j-nut-...040-range-2057 or https://www.auveco.com/j-nuts/j-nut-...nel-range-2420 One of the vendors has to have them in small qty.... I'm 99% sure I have bought them before. |
#4 | |
![]() ![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#5 | |
![]() Join Date: Dec 2009
![]() Thanks I was fix'in to walk out in the cold and try to measure mine.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Thanks you all for the very helpful info.
Happy New Year 🍻 NGN Nick |
