Old 01-29-2024, 02:22 PM   #1
KevinK7
KevinK7's Avatar
Exhaust band clamps, general (fitment) question
Question on band clamps, specifically SUMMIT brand if anyone has used them. Do they normally go on easy?
I've never used them before, and wasn't expecting to 'fight' with them to get over the pipe ; )
Since there doesn't appear to be dropdown pipes available for a 396 with factory manifolds (and no local shop with a mandrel bender) I'm starting to gather exhaust parts for my truck (68 C20 Utility, 396 w/ factory manifolds).
I'm planning to go with 2.5" system, I placed an order with Summit for a pair of FLowMaster FlowFX mufflers, some 2.5" (lap joint) band clamps, etc.
Link to band clamps: https://www.summitracing.com/parts/SUM-681250
The parts arrived and it was nearly impossible to get the band clamps on the muffler. I had the nuts backed out to all but 2-3 threads and still could not get the clamps in place.
Eventually by removing the bolts, spreading the band around the muffler/pipe, 'clamping' it with large pliers, I was able to get it.
This may be normal, I don't know, but hoping others can shed some light.
Thanks,
Kevin
Apparently I'm not the first person to run into this...
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 01-29-2024, 03:10 PM   #2
TotallyHucked
TotallyHucked's Avatar
Re: Exhaust band clamps, general (fitment) question
That's pretty normal. I've got them on my '85 at the headers and that's how I have to get them on, even after 35k miles on them
1985 GMC Sierra Classic
Chopped down wrongbed
Cammed LH6 5.3/T56/3.90
Walker Tuned
5/8 drop
US Mags
TotallyHucked is offline   Reply With Quote
Old 01-29-2024, 03:38 PM   #3
72c20customcamper
72c20customcamper's Avatar
Not from Summit I got the 3” x pipe exhaust for my Chevelle from Pypes. Same issue I just went and bought longer SS bolts . Been 10 years no leaks
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 01-29-2024, 03:51 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Clamps are for slip fit junctions
Old 01-29-2024, 05:25 PM   #5
LS short box
They make the clamps shown above for slip fit and also non-stepped type for butt connections.
I used to use the wide type on my hot rods for years but now I use the 1" wide clamps like they use on late model vehicles. You just need to make slots in the exhaust or muffler tube so the clamp can clamp down.
Old 01-29-2024, 05:50 PM   #6
KevinK7
KevinK7's Avatar
Thanks for the replies guys...
The more I ask around (and from your responses) it does appear this is normal.... editing that "normal" may not be the correct word, but 'expected at times due to variations with brands/pipes' ...might be more accurate ; )
Thanks again,
Kevin
'68 C10 50th
Old 01-29-2024, 07:13 PM   #7
72SB
I used the same ones on my 2 1/2" FX mufflers to OTA pipe, no problems. Slip fit which they call lap.
72SB is offline   Reply With Quote
Old 01-29-2024, 11:48 PM   #8
MikeB
MikeB's Avatar
We know that the muffler pipe ID is designed to slide on a 2.5" exhaust pipe. But the OD depends on pipe wall thickness. Could be that your mufflers' 2.658" OD is a bit on the large size. FWIW, I've bought them from a few different vendors, but haven't had the problem you've described.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-30-2024, 07:55 AM   #9
KevinK7
KevinK7's Avatar
Mike, Thanks for your reply. A buddy of mine locally stopped over and (as you) said he definitely didn't have this issue. On the other hand, he noted, "well, at least they won't slip..."
I was on the fence of returning these Summit ones and trying another brand, but with the thought in mind that they won't allow the pipes to slip/turn, I'm going to go with them.
I may not get into this for another month or so, but I will update when I do.
Thanks again,
Kevin
'68 C10 50th
Old 01-30-2024, 10:46 AM   #10
jerry moss
Born Psycho
jerry moss's Avatar
exhaust tubing is always measured O.D. the muffler neck is measured I.D. that way the pipe will slip inside the neck of the muffler. that's how it's been as long as i've been working in a muffler shop(39 years and counting)
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 01-30-2024, 02:37 PM   #11
MikeB
MikeB's Avatar
Yes, that's what we said above.
The muffler pipe is meant to slide over a 2.5" OD pipe. There may be some kind of standard for its OD, but its ID is the critical dimension, whereas OD is a function of wall thickness. In this case that's .079". I'd bet some muffler pipes have thinner wall thickness (.0625"?), which would have made for easier clamp installation.
To the OP: I have leaned to torque the heck out of the clamp bolts, or you will see some condensation drip out. Also, those clamps will be easier to reinstall once they take the shape of the pipes.
Mike
Old 01-30-2024, 06:22 PM   #12
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: Exhaust band clamps, general (fitment) question
sorry Mike I misunderstood how you worded it-besides that it was too early in the morning when i read it you are correct in wall thickness variations, the thin wall tubing has a tendency to kink when bending and will split when you expand it. we only use thick wall aluminized tubing at work, here in commifornia it last a loooooooong time.
jerry moss
