Old 02-15-2024, 11:46 PM   #1
biketopia
350 sbc roller block
Seasoned block, standard bore, never machined. Spun a main bearing, should probably be line bored and cleaned up. Block, crank, manes with bolts were correctly marked during disassembly. Also includes crank with balancer bolt&washer, cam thrust plate, & lifter spider. Located in Warrenton (20187) or Chantilly 20151, $150obo. For another $50 I'll throw in a set of ARP rod bolts for the build.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 02-18-2024, 12:13 AM   #2
biketopia
Re: 350 sbc roller block
Sold locally
