Old 02-29-2024, 05:42 PM   #1
BobTheTrucker
BobTheTrucker's Avatar
1957 seats
Will the front seats and center console out of a 2002 Tahoe fit in my 57? Has anyone done it and how was it done? Any pictures? My 57 is a 3100.
BobTheTrucker is offline   Reply With Quote
Old 03-01-2024, 02:26 AM   #2
leegreen
Re: 1957 seats
I have 2004(ish) gm pickup buckets, the kind with integral seat belts, and from an extended cab so they tilt forward. My truck is AD not TF so you have a couple inches width more to play with. These are comfortable seats and work OK in the AD. Some people will hate on the headrest, but I have been rear ended a couple times and consider headrests essential. I like the simplicity of the seatbelt install, but that bump on the seat is a little ugly.
In the AD, with the console there is no way the doors would close without squishing the front corners of the seat a lot and the seat does not line up with the wheel. Without the console and with the seats positioned nicely in the cab there is about 6" between them.
These seat rails sit flat on the floor, so I marked the holes and made up top and bottom plates to bolt through with some grade 8 bolts. Dead easy.
I have power seats so there is some height adjustment, I'm 5'11" and have the seat height near the middle of travel and very close to stock AD seat height. I took some pains to enlarge the column mount hole at bottom of dash and center it between gauges to get the wheel as high as possible
Gas tank is under bed, seats moderately upright and all the way back gives enough room for me or my 6' son to be comfortable driving. Manual trans too. A bit more seat travel would be OK so you can recline a bit more, but the seating position is very close to the bench in my '95 Sonoma. but more comfortable as these are better seats
leegreen is offline   Reply With Quote
Old 03-01-2024, 02:28 AM   #3
leegreen
Re: 1957 seats
this thread: https://67-72chevytrucks.com/vboard/...d.php?t=591011
sounds like the console from some trucks of that age fit TF, some don't.
Old 03-05-2024, 01:41 AM   #4
_Ogre
_Ogre's Avatar
Re: 1957 seats
If you're a munchkin, anything will fit. Seat backs in newer vehicles can be thicker than TF trucks, as leegreen pic indicates. Munchkins can bolt the seat to the floor and go with it. I used 07 Ford fusion seats on a 6 inch pedestal and chopped 6 inches from the height, plus I removed the head rest. At 6'4" I am comfortable in the cab, as 3 power tours and 38,000 miles prove.
Lots of pictures in my build thread
shop air compressor timer
