Old 07-09-2024, 08:38 PM   #1
Don D
Junior Member
Automatic column shift tilt steering column.
Automatic column shift tilt steering column for 67-72 Chevy truck. The column originally was in a RV & is now a direct bolt in for a truck. I took pictures of a factory truck tilt next to the one out of the RV so you can see. The neutral safety switch was moved to the correct truck location. It was stripped down & cleaned, checked for worn parts & replaced if needed. It was painted back black & reassembled using the following new parts. Turn signal switch & wiring harness with the correct curved wire connector, lower bearing, lower bearing retainer, neutral safety switch, upper rubber seal, lower rubber seal & retainer, indicator lense. Indicator pointer, hazard light knob, tilt & turn signal lever, shift lever was rechromed, cancel cam cleaned & tested. Column is ready to bolt in. $595.00 plus shipping. / Payment - Personal Check or Postal Money Order. / Shipping to the US only.
Don D is offline   Reply With Quote
Old 07-09-2024, 08:38 PM   #2
Don D
Junior Member
Old 07-09-2024, 08:41 PM   #3
Don D
Junior Member
More pictures
Old 07-13-2024, 12:39 PM   #4
Don D
Junior Member
More pictures
Column has been sold. Will have another one ready soon.
