04-29-2024, 10:39 PM | #1 |
66 c10 radiator and fan shroud
Hi all,
I have a 66 c10 that had a straight six but now has a v8 sbc. I need suggestions for a radiator and fan shroud combo. The fan shroud I purchased is too wide for the radiator even tho it's a 66 c10 fan shroud. Not to mention the new shroud would wrap around to the left and right side of the radiator with upper and lower holes for mounting it to the sides of the radiator. Any suggestions or ideas? |
04-29-2024, 10:46 PM | #2 |
Re: 66 c10 radiator and fan shroud
If you want to use the correct v8 fan shroud, you'll need to also use the correct v8 radiator and set it in the correct spot on the top of the crossmember. The inline 6 radiator sat between the frame rails and was skinnier. You will also need to run the correct short water pump to work with the factory type shroud. You can buy the upper v8 mount and side baffles for the shroud from a couple of the typical suppliers. I think someone also sells the lower mounts for the v8 radiator.
Don't do what the previous owner of my truck did. He hacked the frame rails up to fit the v8 radiator in the inline 6 spot, big sad.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-01-2024, 05:16 PM | #3 | |
05-01-2024, 08:36 PM | #4 | |
