Old 12-03-2016, 03:53 PM   #1
ratty69
Upper rad hose for sbc with serpentine belt.
My apologies if this has been covered before, but I couldn't find the info when I searched.
So the upper rad hose didn't fit right on my 350 with a 92 Sonoma 4.3 accessory group. The hose was pushed tight against the alternator and very close to the fan. Figured there had to be a better way, so started digging through memory and catalogs. I came up with this:
Thermostat housing for 84 G20 w/350
http://www.rockauto.com/en/moreinfo....045842&jsn=538
AND,
Upper rad hose for 67 Firebird w/400
http://www.rockauto.com/en/moreinfo....402805&jsn=694
Truly plug and play. NO mods required and lots of clearance.
Installed pic ( Please forgive all the fugly, making it work first. Pretty comes later. ) :
ratty69 is offline   Reply With Quote
Old 12-03-2016, 04:15 PM   #2
coreyjhen
Re: Upper rad hose for sbc with serpentine belt.
Looks nice. Would a plain vertical water neck also work?
coreyjhen is offline   Reply With Quote
Old 12-03-2016, 07:02 PM   #3
ratty69
Thanks. A plain vertical neck probably won't fit with a 14" air cleaner. The van water neck is offset forward enough to clear.
Old 12-03-2016, 11:59 PM   #4
Mikeextrafast
So you used all the acc. Off a 4.3 ? How did it all fit up ?
Mikeextrafast is offline   Reply With Quote
Old 12-04-2016, 12:09 AM   #5
Tquillen
My accessories came off an early nineties Camaro, and I used the factory 1969 C10 SBC upper radiator hose. The F body serpentine system positions the alternator lower on the engine.
Tquillen is offline   Reply With Quote
Old 12-04-2016, 12:32 AM   #6
ratty69
It all fits perfect, including the crank pulley. YMMV however, since most people say the crank pulley's different. If you have doubts, take the crank pulley from the same year sbc to be safe. Make sure you take ALL the hardware, braces, water pump, and fan too. Just swap your fitting onto the p/s pump and you can use that too.
Really really easy. Anything else just ask...
Old 12-04-2016, 12:37 AM   #7
ratty69
My truck came setup like this. The brackets were cut and pulleys cracked so it had to be replaced. Old 4.3 stuff is dirt cheap and everywhere...
Old 12-04-2016, 07:19 PM   #8
72_K10_Vegas
72_K10_Vegas's Avatar
That's great info. Having the same issue. My real problem has been the lower radiator hose on the GM serpentine kit on my 72 350 sbc. Anybody have a part number or thoughts?
72 K10
72_K10_Vegas is offline   Reply With Quote
Old 12-04-2016, 07:54 PM   #9
jjzepplin
jjzepplin's Avatar
I used the metal bendable kind and it worked out great on one truck. I cannot remember what I used on my other truck. But it is stock rubber I think.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-04-2016, 08:49 PM   #10
72_K10_Vegas
Yeah, I have been looking at all options. I purchased the R&D radiator out of Georgia. Its all aluminum so I removed the lower radiator neck and angled it so it would give me better clearance over the frame. Looking at early 90's truck LR hoses, and cut in a SS coupling.
I just am really hoping somebody has a manufactures molded hose out there.
72 K10
Old 12-04-2016, 10:25 PM   #11
ratty69
Can you post a pic of your lower rad neck and its diameter? If it's 1.75"( stock size ) and angled up same as stock, then a stock hose for an AC truck ( ACDelco 24035L ) will fit with about 1.5" cut off the rad end. This is what I'm using.
If the neck is 1.5" and straight ( 73-87 style ) then you need a 73 hose. My truck had this when I got it.
Hope that helps.
Old 12-08-2016, 06:50 PM   #12
72_K10_Vegas
Hey Ratty,
73 Lower Hose worked perfect. Thanks for the info
72 K10
Old 09-09-2018, 11:12 PM   #13
rcazwillis
Thanks for the info! This saved a ton of time for me. Ordered the water neck and hoses from RockAuto. Water neck was in a box with the correct info, but the neck was no where close to being the correct part. Credit issued, ordered it off Amazon. Part was correct and is now bolted on.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 05-07-2024, 03:32 AM   #14
Triple7
Performing necromancy but this was very helpful in 2024 and needs to be pinned near the serpentine belt conversion posts.
Triple7 is offline   Reply With Quote
