Old 02-24-2004, 01:00 AM   #1
aggiedave98
lmctruck versus jcwhitney leaf springs
lmctruck.com has 'factory' leaf spring replacements for my '89 suburban 2wd that are 5-leaf like oem for $139
jwhitney has 8 or 9 leaf for $99 or $115 respectively.
what do you think the pros and cons of each are? i don't care about the price difference.
I'm going to go ahead and use blocks and the new leaf springs.
Thanks.
aggiedave98 is offline   Reply With Quote
Old 02-24-2004, 01:11 AM   #2
bpmcgee
bpmcgee's Avatar
JC Whitney has ALWAYS struck me as an outfit for getting really cheap stuff. They've only reinforced that impression lately.
I'd get the LMC Truck for that reason, and because it would be supporting a vendor who specializes in our trucks.
Brian
bpmcgee is offline   Reply With Quote
Old 02-24-2004, 01:32 PM   #3
greatdaen
I don't know anything about LMC, but I'll second the opinion about JCW.
-dch
greatdaen is offline   Reply With Quote
Old 02-24-2004, 02:28 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
If you order from LMC, be absolutely sure what you need. They have no tech support to help you, so you are on your own. Also, be prepared to ship them back when they get there and are wrong. Been there, done that. It's not a pleasant experience to ship leaf springs.
Unless they have changed the way they list them, they don't tell you if they are 52" or 56". This was where I got screwed. I ordered what I thought was right, but when I got them, they were 52" springs and mine are 56". I could have used them and moved the rear hanger up 4", but I wanted to keep the 56" springs.
I would talk to the folks at http://www.espo.com/ if I were you. They actually know what you need.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-24-2004, 05:29 PM   #5
DCRANER
I know LMC is a good source for our trucks, but you may want to check with Eibach Spring. They are in my opinion the best quality and are usually very helpful. They can also suggest a spring for towing, performance, ride quality, etc.
Doug
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL.
DCRANER is offline   Reply With Quote
Old 02-24-2004, 06:05 PM   #6
cdowns
cdowns's Avatar
something heavy like that i'd check to see if they're available locally (yellow pages)that way you're not going to be screwed if there's a mixup you can look and measure b-4 paying
Old 02-24-2004, 06:37 PM   #7
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
well, if you are going to use lowering blocks, you don't need alot of leafs. you need 3-4 leafs only. you could go monoleaf and use blocks too, that is an option. I have ordered springs from JC in the past, never a problem. Returning/exchanging thru them is also easy. LMC has been good so far, but I have heard many stories of return/exchange hassles. Have you tried any other stores? Good luck!
Shamrock Customs
Forever-in-the-Future Custom Shop
2009 Mitsubishi Lancer GTS daily driver
1956 Chevy Stepside rodstoration on winter hold
ShamrockCustoms is offline   Reply With Quote
Old 02-24-2004, 07:28 PM   #8
swervin ervin
Can't use lowering blocks on a a 89 because the axle is under the leafs. It would be raising blocks if you did.
Mike
1985 Chevy C-10
Old 02-24-2004, 08:06 PM   #9
Prerunner1982
Prerunner1982's Avatar
and he is wanting to lift it..... not lower it..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-25-2004, 12:24 AM   #10
ShamrockCustoms
Project56 on hold
Ah, I see. He did not specify in his post. In that case, he might opt for the 8/9count leaf, would be more heavy duty for off-road and heavy load capacity.
Now Swervin, you already know a flip kit will solve that! hehehe
Shamrock Customs
Old 02-25-2004, 02:25 AM   #11
swervin ervin
Yep. Just couldn't resist.
Old 03-02-2004, 02:51 PM   #12
smitty62
smitty62's Avatar
C'mon people!! Neither JCW or LMC make springs! They buy them from a wholesaler/manufaturer for Pete's sake!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 03-02-2004, 04:07 PM   #13
Prerunner1982
nobody said they made them...only that they offer them. i could say that summit offers a 33" mud tire for $156.00, and then say Jegs has a 31" mud tire for $125.. and ask which one would be better... i however never said they made them.
Jon
Oklahoma Roll Call
