fuel
![]() Join Date: Jul 2003
need advice on where to put valves??
just wanted to see where you guys put your valves. im trying to figure out where to put mine.
this would help me alot, i want to do this before i put my cab on, thanks alot!! chris
72 w/67 front clip 415ci fuel injection t56 air ride 18/20's |
fuel
TTT
Project92 SWB stepside
I am planning on putting my things under the bed at the front of the cab. Maybe in the bed at the front near cab. I am running all electric valves and gauges so air lines will be minimum.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
Happy to be here
![]() Join Date: Mar 2000
On my 77 Cheyenne, they are mounted on a custom panel under the cab where the "other" gas tank would be if I had duals.
Heres the panel they are mounted on- ![]()
Happy to be here
And here they are mounted under the truck-
Back from the Dead
I made a set of brackets for mine out of angle-iron that mounts the the outside of the frame. I am only running a F/B system with SMC valves. They are mouted underneath the doors and make for a nice sound effect when I drop it
The only Carb that matters to me is the one under my hood! Salem, Oregon |
www.loweredd.com
Mine are on the passenger side where the gas tank would have been too. My tank is also, and my compressor. When I take the other tank off and put in the fuel cell, I will add another tank on the drivers side, and put an engine driven compressor on the LT1.
