Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 04-12-2004, 09:18 PM   #1
granddaddys53flatbed
Question 53 3/4 rearend needed
Ive got a 53 3/4 chevy that has all of the chunk out of the rearend all i have is the axle shafts i either need the chunk or a used rearend anyone got a good one near nashville TN. email me if ya do i need one. thanks
granddaddys53flatbed is offline   Reply With Quote
Old 04-16-2004, 11:33 PM   #2
gaddman
gaddman's Avatar
I've recently got a 50 3/4 3600 4spd. It's my first experience with these trucks. If your 53 has the same rear as mine, the original gear ratio was 4:56. Based on my research, the 67-72 3/4 (C20) has the same "guts" as ours. If you can find one that had/has an auto transmission, then the ratio should be 4:10. You can pull the whole gear assembly out and bolt it right into your housing, using your original axles. Then you will be able to travel faster than 45mph without blowing it up :-) I found one for $100 and am going to try it out.
Check these out:
http://community-2.webtv.net/Tom3600/REARENDGEAR/
http://www.pirate4x4.com/tech/bible/index.html#GMRE
www.stovebolt.com
Good luck.
Gaddman
Scottsburg, In
67 SWB w/93 step bed
68 LWB Fleetside C10 Custom
50 Chevy 3600
74 Norton Commando 850
72 Norton Commando 750
gaddman is offline   Reply With Quote
Old 04-20-2004, 05:04 PM   #3
TATE228
my truck has a 4:11 from the factory it even says in the manual
it has a four speed mabe that makes a differance but a 4:11 won't make much differance the truck will still be slow. you can get a 3.55 from chevy duty for only $400. lol
-1971 K20 350/sm465
-2004 1500
TATE228 is offline   Reply With Quote
Old 04-26-2004, 11:07 AM   #4
cochran63
cochran63's Avatar
55 1st series parts truck
There is a man down the street that has a disasembled 55 3/4 ton gmc for sale. the body is in pretty good condition. He is wanting 400 for the whole thing.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
