Old 04-08-2004, 09:01 PM   #1
Brimow525
4wd Disc Conversion
I did a search and saw a lot of info about 2wd conversions but not alot about 4wd. I have a 70 K20 with D44 with drums in the front and a Eaton in the rear. I want to either convert the front to drums OR swap out both rears for a newer style with front disc. 4:10 gears right now but not really concerned about what gears but more concerned about what vehicles I should belooking for, for the donor parts. Buying a kit (although is a great idea) out of a book is just too much in my opinion. Can I look for 73-88 rear and pretty much just bolt on? Or do I need to stick to the mid to late 70's for the easiest conversion. When I do this I am going to replace every bearing, seal, bushing etc. before it all gets installed. Any info or help as to what I need to look for would be great. I am a newbie at the conversion stuff, so pro's, go lite on me.
Cuttin' Grass and Kickin' A** , and We're Running Out of Grass to Cut!
Brimow525 is offline   Reply With Quote
Old 04-08-2004, 09:05 PM   #2
Brimow525
By the way, heres a pic of the truck.
Old 04-08-2004, 09:06 PM   #3
1969 GMC
1969 GMC's Avatar
if you want to swap axles, then you can swap in a dana 44 from a '71-'77 K/20 truck or burb. you can also use the 10 bolt front axle that was used into the 80's. and if you're lucky enough to find one, you can use a dana 60 from a Dodge 3/4 or 1 ton, or a 1 ton GM, as long as it will fit. good luck in your swap.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-08-2004, 09:10 PM   #4
Brimow525
what do I need to look for or measure on the dodge? As long as its a d44 or d60 I'm OK? Or only chevy and dodge trucks?
