11-28-2023, 01:43 PM | #1 |
Where to buy the correct valve stems for Alcoa dually wheels
I had new tires put on my Alcoas back in June at discount tire with new valve stems. These really aren't the right size and if I bump them when I'm washing the truck it they seem to start leaking. I asked discount tire if they carry the correct ones and they don't. I need the metal bolt in style with the angled ones for the rear wheels. Also if I knew the actual hole size I could do some research myself. I don't have that option on my wheels as they're currently on my truck. I don't want to ruin $1,700 worth of tires Even if I do have a road or hazard warranty. I really should have saved the old valve stems and just got new seals but I didn't know this was going to be an issue
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
12-01-2023, 12:16 AM | #2 |
Re: Where to buy the correct valve stems for Alcoa dually wheels
I had new BFG ATs put on my old Vectors at Discount and asked them for metal stems. They said they did not carry them???
I will bring my own next time. Valve stems for autos have been .453" or .625" forever. When I was a tire buster in the 70s only ford trucks had the big hole. Many metal stems come with both size gaskets. I have a set of Alcoas in the garage with stems in them still. I think they were off a GMC front drive motorhome. I will try to get a measurement this weekend.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
12-02-2023, 01:29 PM | #3 |
The Older Generation
I can't help with the size but you might check the Milton web site and see if you can come up with anything. https://miltonindustries.com/collect...re-tire-valves That's where I had to get my oval valve stems. for my rear dual wheels. You might try calling them also. Be sure and report back to the thread if you would, when you find what you need. LockDoc
12-02-2023, 03:36 PM | #4 |
Mine are Dill TR543
METRIC CLAMP-IN VALVES Compatible with aluminum wheel designs with .389 valve hole. Produced with Viton grommets, all KEX Tire Repair clamp-in valves are equipped with high temperature valve cores. • Viton grommets offer a greater temperature range, a better seal, and a longer service life. • Easier installation than other Metric valve designs TR-543 Clamp-In Valve TR#: TR543 Hamaton: 1-502 Dill: VS-543 Haltec: TV-543 Myers: 24252 Specification Description Valve Size mm 60 Box/Qty 100 Your results may vary.
12-04-2023, 11:10 AM | #5 |
Thanks to everyone for the input. I will get to looking.
12-04-2023, 03:54 PM | #6 |
Go to a tire shop that does medium truck tires. I believe it's TR545E but I cannot for the life of me remember for sure. You need to be able to get to your rear inners through the hole in your outers.
1970 C10 l/b 292/4spd Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062 |
12-06-2023, 12:52 PM | #7 | |
12-08-2023, 10:28 PM | #8 |
https://www.dillvalves.com/product_c...lamp-in-valve/
https://www.dillvalves.com/product_c...lamp-in-valve/ https://www.dillvalves.com/product_c...lamp-in-valve/ These all have the stem hole I have. https://www.dillvalves.com/product_c...tire-valves-2/
