LS swap with PSI wiring harness
I'm in the middle of installing the wiring harness from PSI into my 67 C10. Running a L92 with 6L80 trans. My main question is which wire do I tap into behind the ignition switch on the dash that would go with the Ignition Feed wire from the PSI wiring? It calls for 12v in start position and also in accessory but no power when off. Does anyone have a picture of the exact wire from the back side of the switch where the wires come out?
Thanks much! |
Re: LS swap with PSI wiring harness
I used the big purple. That's the excite to the starter. Pick it up after the Neutral Safety Switch on the column, if you have an Automatic.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
My truck was originally a 6 cylinder manual 3 speed on the tree. I do know I need to add a neutral safety switch but didn't come with one.
I'm sure your harness came with an ignition relay, right? If it didnt you will need to add one, but if it did, then you will turn that relay on with the wire that originally went to the coil. The pink wire in the top of the pic.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Okay. That was the wire I had figured but good to confirm it.
Thanks much! |
Where did you go thru the firewall with your harness?
I will be adding vintage air system and don't want to cut a hole in the wrong spot. |
#7 | |
Posted via Mobile Device |
