Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 04-13-2016, 06:51 PM   #1
57taskforce
All about them K’s
57taskforce's Avatar
Need help, 69 c/50
A co worker has a 69 c/50 that has what he says is a 327 and hydraulic brakes. He said it's got a booster on the firewall and one back under the bed. The booster under the bed is shot and he needs to move it around and was hoping maybe I could find out a way to make he brakes work for him to drive it some. He said the booster in the rear doesn't seem to be available any more. Anyone know how to bypass this system and make it road worthy at an affordable price?
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 04-17-2016, 08:21 AM   #2
63 & 64 Bowties
and a few others
Re: Need help, 69 c/50
I don't have an answer for ya, but maybe a bump to the top will get some attention.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 04-18-2016, 12:26 AM   #3
colgad
colgad's Avatar
Re plum the brake system, scrap all the lower booster and split the system using a new master and booster in the engine compartment. Do it once and do it right. It really is simple if you stand by and look at it. Master to a T to the front brakes, Master to the rear axle and a T to each rear drum. I used a 90's 3500 silverado Master and Booster. A little drilling was required on the firewall but simple really. No simple fix for the front drum brakes without changing the spindles to P30 food van/motorhome spindles. But that will give you disk in front. The rear is easier because most 90's TopKick rearends can be made to fit. If you rebuild the drums they can be made to work well. I did it once but never again. I would rather do disk anyday.
To drive it home, I would just use the front brakes, take the line out of the T that is mounted on the front frame that heads to the rear and put a plug in it. You can get plugs at your auto parts store.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 04-20-2016, 10:54 PM   #4
57taskforce
All about them K’s
thanks for that. I passed the info on to my buddy.
Tyler
