Old 02-21-2023, 05:50 PM   #1
hotrod1
56 - autocross
hotrod1's Avatar
Gas Pedal - Kind of a poll - 55-59
55-59 Chevy Trucks
What aftermarket gas pedal are you using? Any good? Suggestions welcome.
hotrod1 is offline   Reply With Quote
Old 02-22-2023, 09:22 AM   #2
my56chevytruck
my56chevytruck's Avatar
Re: Gas Pedal - Kind of a poll - 55-59
Here's what I have in my 56, 2nd series. The mounting surface on the truck floor had to be alterered with a offset piece (I made) in order for the gas pedal to be inline.
Speedway Motors | #91655013
Speedway Billet Aluminum Accelerator Throttle Pedal
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 02-22-2023, 10:04 AM   #3
dsraven
have you modified the firewall and floor area for engine clearance or do you have a stock scenerio? I ask because sometimes the mod has decreased floor space in the accel pedal foot well area. are you looking at drive by wire, solid linkage style or a cable operated set up? a pic of your floor area may help.
Old 02-22-2023, 11:43 AM   #4
unclebrad
unclebrad's Avatar
I might prefer something a little less flashy but this does the job.
https://67-72chevytrucks.com/vboard/...1&d=1677080537
unclebrad is offline   Reply With Quote
Old 02-22-2023, 12:19 PM   #5
youngrodder
youngrodder's Avatar
I'm using a similar looking pedal and I ended up painting mine black for that exact reason.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-22-2023, 05:28 PM   #6
mr48chev
mr48chev's Avatar
I've got a Lokar knockoff that should sit and work like the stock pedal that has the cable on the outside of the firewall.
This being the 240 dollar real deal but I didn't pay near that for the as my dad used to say "almost as good" unit that probably came from Hoffman group.
The main thing well beyond appearance is that the gas pedal has to be comfortable to drive with. It doesn't matter how great looking it is if it gives you cramps in your leg, ankle or foot or is uncomfortable to drive with.
I think I have the pedal out of a 76 Mustang II that I scrapped out in the truck now. That was after a half dozen other pedals over the years one lasting one day before I took it back out and threw it in the trash barrel.
I think this is the cheaper one that I bought off Ebay quite a while ago eBay item number:313768029638
My ongoing truck projects:
Old 02-23-2023, 08:07 PM   #7
Black_Sheep
Black_Sheep's Avatar
Lokar “Lakester”, I had to fab up a mount to get it where it was comfortable…
Black_Sheep is offline   Reply With Quote
Old 02-27-2023, 04:44 PM   #8
QBRacing
lokar floor mount.
should have mounted it a little higher to allow for the underfelt and carpet but it works great.
Q
QBRacing is offline   Reply With Quote
Old 02-28-2023, 10:21 AM   #9
dsraven
blacksheep, that looks REALLY nice. not just the pedals, the whole thing. I like how you have spaced the pedals apart enough to be prctical, and the carpeting turned out like it was factory made. is the centre section a removeable plate for access to the engine area, or just a detail?
Old 03-10-2023, 08:53 PM   #10
Black_Sheep
Thanks for the kind remarks. I put a lot of effort into the interior so I appreciate when someone notices.
The center piece seemed like the best work around because of all the angles and weird contours where everything converges. It was shaped with a steamer and glued into place, overlapping the raw edge of the main piece of carpet where it was cut to accommodate the hump in the firewall.
There are pictures in my build thread that illustrate how it was done, better than I can explain it.
Old 03-10-2023, 09:03 PM   #11
dsraven
black sheep, your build is show quality. very nice attention to detail. you should be proud.
Old 03-11-2023, 06:54 PM   #12
G&R's57GMC
G&R's57GMC's Avatar
I have the Lokar Pedal and I want the stock look , so I found if you grind off the nub on the backside of the stock pedal it will slip over the Lokar Pedal perfectly and a couple small screws will secure it to the Lokar pedal.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 03-28-2023, 01:44 PM   #13
bosco
bosco's Avatar
Here's the pedal I used. It's from Lokar and designed for a C10, but worked great in my application.
bosco is offline   Reply With Quote
Old 03-28-2023, 02:52 PM   #14
Brians59
I am using the factory GM electronics, steering column, etc. from a mid 2000s Yukon in my 59.
To get the drive by wire gas pedal to fit, I had to weld a bracket to the steering column and attach the pedal there.
Brian
Project: 1959 Chev Apache Fleetside
Brians59 is offline   Reply With Quote
