02-28-2010, 09:55 AM | #1 |
questions about front disc swap on 70 c10
ok i got a 1970 c10 that i bought at the end of last summer off of a good friend of mine that just wanted it out of his yard and was going to junk it so i gave him 200 for it and its not that bad. i want to put front disc on it but i know there has to be a way to use factory parts. cam i use the front control arms from a 73-87 c10 cause my lowers are shot so they need replaced any how and i was just going to get every thing of the front suspension off the 73-87 and the master and prop valve also. will this all work
02-28-2010, 11:47 AM | #2 |
Re: questions about front disc swap on 70 c10
I'm not real familiar with the '73 and up trucks but as long as you take everything, spindles, control arms and steering linkage, you'll be in good shape.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
02-28-2010, 03:37 PM | #3 |
ok i just didnt want to go to the junk yard and buy all the front end parts if it wasnt gonna work. so my next question is for front drop springs would i use 67-72 or 73-87 or are they the same. cause i would assume that the 71-87 c10 would have nearly identical front suspension componants
02-28-2010, 04:01 PM | #4 |
I am a Referee of life.
You can use the complete front suspension.Either take the whole crossmember and swap it(this requires drilling a couple of holes out) or swap from the control arm shafts out.Use the later tie-rod ends and center link and if it has PS you might as wll upgrade that while you're there.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-28-2010, 04:23 PM | #5 |
so my best bet is to just get a front stub cut. im not going to swap crossmembers that just seems to alot more work then you need to do if you can just switch the control arm shafts thats much easier and less hassle. i didnt even think about the p/s swap but thats an excelent idea does the 73-87 p/s box bolt right onto the 70 frame. i have the pump and brackets and pulleys from my sbc s-10 cause i took all that off it and put a 4cyl manuel box on it
02-28-2010, 07:40 PM | #6 |
The PS box will swap, and the coils should be the same from our body style to the square body trucks.
02-28-2010, 10:27 PM | #7 |
sweet well off to the junk yard next weekend for a front frame cut from a 73-87
thanks for all the help guys |
02-28-2010, 10:29 PM | #8 |
Grandpa in the rustmobile...
Also, if ya plan on dropping it anytime soon, they make conversion drop spindles. Drop spindles that accept your exisitng balljoints tierod ends and will use 71-72 and maybe 73-87 bearings rotors/calipers.
good luck! disc upgrade is best ive done to my truck so far! go power disc
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-28-2010, 10:46 PM | #9 | |
02-28-2010, 11:46 PM | #10 |
67-72 parts collector,…
Grab a front sway bar while your at it.
The 3/4 ton trucks have the bigger 1-1/4" diameter sway bars. This is a great upgrade in handling.
03-01-2010, 08:54 AM | #11 |
03-01-2010, 10:24 AM | #12 |
I just moved everything from an 81 to a 68. Moving the crossmember is a good idea since then you know that it was all a system that could be aligned, etc. Also, the U joints are bigger and on a wider spacing on the new ones. Easier to move the whole thing than to try to mix and match. You can take out the whole front end on either truck without even taking the springs/ball joints out. Just 14 bolts/nuts to remove, steering to disconnect and brake lines. You will need to widen some of the holes and drill 2 new ones.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
03-01-2010, 10:25 AM | #13 |
oops. I meant U-bolts.....
