Old 05-19-2004, 10:14 AM   #1
'70_402
'70_402's Avatar
What is the Difference in 67-72 doors
I have heard alot of people want 72 doors on thier trucks.....what is the difference in the doors from 67 to 72....is their any advantage??
'70_402 is offline   Reply With Quote
Old 05-19-2004, 10:17 AM   #2
71-longbed
Its Magically Delicious
71-longbed's Avatar
from what i understand (which is little) ...72 doors have a screw below the wing window handle that holds the door together better ... its common for these doos to want to seperate over time
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 05-19-2004, 11:26 AM   #3
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
The 72 doors also have different door panels and arm rests and different window mechanisms. I think the outer door skins are the same though.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 05-19-2004, 01:10 PM   #4
silvertonguedevil
silvertonguedevil's Avatar
To the best of my knowledge, the '72 doors only difference is in the way the door panel attaches to it. The shells are otherwise the same. I have one of each but have never had the door panels off.
I also think the armrest mounting holes are higher....?
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 05-19-2004, 06:31 PM   #5
silvertonguedevil
I just stumbled across something actually. Go to the homepage of this website, click on tech articles, then click on "door interchangeability" and there you have it!
-Greg
1974 C20 Cheyenne
Old 05-19-2004, 08:36 PM   #6
DR67
DR67's Avatar
Can you buy the bolts that go in the 72 doors, or is there some better way to plug the hole?
DR
Dave
Knoxville,Tn.
DR67 is offline   Reply With Quote
Old 05-20-2004, 11:09 AM   #7
silvertonguedevil
Which holes? The armrest mounting holes?
-Greg
1974 C20 Cheyenne
Old 05-20-2004, 11:42 AM   #8
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
There are a couple of differences in the doors, although the 72 door does bolt onto the 67-71 trucks without issues. The 72 doors are set up for the plastic door panels witch use plastic clips and 1 screw about half way up the back side of the door panel to attach it. The 67-71 doors are set up for interior panels that need an upper trim peice that is held in place with 4 screws to hold the top of the door panel in place and also have 4 machined screws that pass through the door panel, and into 4 little 1/4" nuts that hold the bottom in place. The nuts them selves are mounted into a little clip that attaches to the door. Then there is the obviouse difference, and that is the upper screw hole for the screw that supports the top of the window channel near the vent window assembly. We now carry both style doors fot the pickups, panels, suburbans, and blazers, for anyone who is interested. Same cost for both styles. By the way the arm rest holes are the same. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-20-2004, 01:01 PM   #9
Mixup
Isn't the window regulator different on a 72? I think the shaft is longer to go through the plastic panel.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 05-20-2004, 01:09 PM   #10
Rod
Yes the inner door and window regulator shafts are longer in a 72 door because of the deeper plastic door panel a 72 has.
Heres a link to my tech post from years back.
http://67-72chevytrucks.com/tech/doors.html
Perhaps I should edit it a little ands update it... Wes had some other points that should be useful in there also.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-20-2004, 05:03 PM   #11
DR67
DR67's Avatar
The hole I was referring to is the one just below the vent window, I read that there was some kind of J-bolt that goes there.
DR
Dave
Knoxville,Tn.
Old 05-20-2004, 05:12 PM   #12
Rod
Yeah the j-bolt is on the 72 door only... it reinforces the area of the vent window... if you look at enough doors you qwill see that some developed a crack near the vent window area from the stresses of opening the vent window forceably. all the years of twisting has had its effect.
