Old 05-13-2004, 11:28 AM   #1
Yukon Jack
Yukon Jack's Avatar
Unhappy Fuel tank hose question
When I dropped my gas tank in the 70 K5 I found the hose that goes from the tank to the filler was in bad shape and needs replacing. I measured the outside diameter of the tank's fuel filler spout and it is 1 3/8".
The LMC catalog shows this fuel hose is available in 2" or 2 1/4" ID. Went ahead and ordered a hose from one of our vendors to see if it would work, hoping there was a miss measurement, but the hose is a true 2" ID so way too big.
Anyone else run into this problem and if so, what did you do?
The local parts houses here don't have a fuel hose in 1 3/8" ID.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-13-2004, 11:49 AM   #2
71jimmy
71jimmy's Avatar
I have heard about this problem, seems no one makes the correct size hose. At least not that I've read about. I'm about to replace my fuel tank also and will likely run into the same problem. Sure hope someone out there has a solution.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 05-13-2004, 12:35 PM   #3
1970blazin
Blazerless:-(
1970blazin's Avatar
What about these guys---
http://www.goldstein-schwartz.com/de...id=23&catid=49
1-17/32" O.D. is pretty close to 1-3/8" o.d. eh?
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 05-13-2004, 12:40 PM   #4
72jimmy4x4
Hello Yukon
I have been looking for the same thing for about 2 weeks and cant find one either. What I was thinking about using is single cord hydraulic line. It is not stock but the gas will not eat through it and should be flexable to get it in there.
Brian
72jimmy4x4 is offline   Reply With Quote
Old 05-14-2004, 11:24 PM   #5
k5hart
k5hart's Avatar
Brian is correct in using that single cord hydraulic line. I was in a hurry when I replaced my tank and didn't want to wait on a new hose to come in from the suppliers so I went to the local industrial supply house and bought the same thing. It worked out just fine. Nice and strong but still flexible and won't get eaten by the gas. Haven't had any problems.
Jason
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 05-15-2004, 08:32 AM   #6
earnhardt221
Hey Jack,
I went to a local heating oil company and asked them where they get thier replacement heating oil hoses.They told me and i went there,found one no problem.
The company was called The Briggs company in New Castle, Del.
earnhardt221 is offline   Reply With Quote
Old 05-15-2004, 09:27 AM   #7
Yukon Jack
Yukon Jack's Avatar
This helps me on a lot of different leads. I just wonder why the correct part isn't sold by the suppliers. That is pretty odd.
Old 05-21-2004, 02:35 PM   #8
Yukon Jack
Yukon Jack's Avatar
Got the hose replaced at a hose supply place about 6 blocks from work - had exactly what I needed. About $10 for a foot and a half - got a little extra so I could cut it to size.
