350 to 383...
Does a 350 block need to be clearanced to make a 383? I have heard they need to be "notched". Others say you only need to get the 400 crank main journals down to 350 size? What is needed to make a 350 a 383?
Thanks ![]()
1972 C10 1972 C20 ![]() |
You need to clearance the pan rails to clear the rods..you may also need to clearance the rods for the cam. You will need a 3.75 stroke crank..either aftermarket or have a 400 crank cut from 2.65 to 2.45 main journal size. If you use the 400 rods you can use 350 pistons. If you use 5.7-6" rods you need special stroker pistons. If you go externally balanced you will need a 400 harmonic damper and flexplate/flywheel..Dont skimp on the machine work and use the best parts you can afford. Measure (or have measured)all bearing clearances. Before you start, have the block tanked and magnafluxed.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Does anyone have a picture of what the block looks like clearanced? What's the cost to have a machine shop do the work, or could I do it myself. Where is a could place to get a stroker kit for the best price?
Thanks in advance...
Insert funny comment.
![]() Join Date: Dec 1999
When I did my build, the crank only hit in the one location. Basically you just gind down until you have a thick paper clip clearance. Not hard to do, jsut mock it up and turn the crank checking for clearance issues on the pan perimeter and the lifter jounals.
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
So the counterwieghts only hit in one area? Can an angle grinder be used?
Fabricate till you "puke"
Sorry, no pics
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#7 | |
All block casting at a little different. Mine only hit in that spot. I used a die grinder to take off the excess.
You can find decent budget kits at strokerkits.com and powerhouse(forget the url) .. make suure you get it balanced though. Quote:
