Old 06-11-2004, 09:23 AM   #1
Effle18
Any ideas? Truck not charging...
My battery was going dead so I figured since it was 5 years old I would replace it so I did, and the new one was going dead. So I thought my alternator wasn't charging so I had it tested and it is o.k. But when you start the truck and disconnect the positive cable from the battery the truck dies. Shouldn't the alternator keep it running once it is started? If the alternator is good what else could it be?
96 Bagged 2Door Tahoe
69 Blazer
Effle18 is offline   Reply With Quote
Old 06-11-2004, 09:28 AM   #2
cdowns
cdowns's Avatar
regulator regulates the charging of the battery that's why it's called a regulator
Old 06-11-2004, 09:34 AM   #3
Effle18
Hmmmm...I thought that was built into the alternator? Or is it seperate?
69 Blazer
Old 06-11-2004, 09:35 AM   #4
dubie
dubie's Avatar
there is a regulator on your rad support on the drivers side. You need that is you have an externally regulated alternator bud
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-11-2004, 09:47 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Is it internall or externally regulated?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-11-2004, 09:51 AM   #6
Effle18
I ass-u-me..d it was internal but it might be external and this would explain everything. As soon as I get home I will check it. What should it look like? A sqaure box with at least 2 wires hooked up to it?
69 Blazer
Old 06-11-2004, 10:09 AM   #7
kwmech
4 wires go into the external red- brown- blue- white
kwmech is online now   Reply With Quote
Old 06-11-2004, 10:15 AM   #8
Effle18
Thanks for the help. I need to get this back on the road.
69 Blazer
Old 06-11-2004, 10:22 AM   #9
smokekiki
Mike
smokekiki's Avatar
The regulator is on the rad support on the drivers side.It has a 4wire plug on it.Take Your altenator to the parts store.Most will check it out for You at no cost,pep boys,autozone,advanced,ect..I just replaced mine,the regulator was fine.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 06-11-2004, 10:45 AM   #10
cdowns
cdowns's Avatar
driverside rad support near horns
Old 06-11-2004, 01:15 PM   #11
72gord
Never enough time!!
72gord's Avatar
Internal regulated alternator has the side plug terminals in line(--) like that, External one has the terminals side by side(ll) like that. Good luck
72gord is offline   Reply With Quote
Old 06-11-2004, 01:53 PM   #12
dubie
dubie's Avatar
what would happen if you hooked an internally regulated alternator up to the external regulator??
Old 06-11-2004, 02:38 PM   #13
Effle18
Yep mine is external then, I have the side by side.
69 Blazer
