Old 06-16-2004, 02:51 PM   #1
68speedalert
Semi-Senior Member
68speedalert's Avatar
A simple factory tach ?
Surely it's not this easy......Converting to a factory tach numberoneson just bought. On the back it shows: 12V and TACH" above the spade terminals. Is that all that's needed? Just a power wire and a wire run to tach side of the HEI unit?
thanks in advance,
Steve
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 06-16-2004, 03:04 PM   #2
fast_dev
fast_dev's Avatar
thats all, just a power and tach terminal.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 06-16-2004, 03:14 PM   #3
smokekiki
Mike
smokekiki's Avatar
Is it a complete tach conversion kit,a replacement for a truck that already has a tach,or just a tach?If just a tach,you would need a lens,backing plate and circut board.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 06-16-2004, 05:55 PM   #4
68speedalert
Semi-Senior Member
Mike,
It's even better. He found a used complete dash for $100. AND it's in good shape. Now as long as I can figure out the wiring and it works, we'll be in good shape.
Steve
Old 06-16-2004, 06:11 PM   #5
krue
Designated A-hole!
krue's Avatar
Love your avatar man!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-16-2004, 06:19 PM   #6
68speedalert
Semi-Senior Member
thanks.
Numberoneson is a lot older than the avatar looks, but it's the right idea for the last 2 years workin on his truck.
Steve
