Old 07-27-2004, 09:50 PM   #1
shannon kaufman
need help bad
Hello i need help bad i have a 70 half ton took the bed off to sand blast the frame and hooked up a pair of tail lights so i can drive it, here is were the problem starts when i hit the brakes no lights i have to get on them hard to get any lights and then the left turn signal comes on i also have no turn signals at all and no braks lights when my head lights are on were did i screw up at thanks for lettin me ramble thanks shannon
shannon kaufman is offline   Reply With Quote
Old 07-27-2004, 09:56 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Your temporary taillight housings are not grounded properly to the truck. Add a short ground wire if you need to.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-28-2004, 06:26 AM   #3
JimKshortstep4x4
Smile
Welcome to the board from West Michigan!
Good luck on your problem, Tx Firefighter is probably right about the ground problem.
Jim
Old 07-28-2004, 07:47 PM   #4
walker
walker's Avatar
Ditto on the ground, assuming everything worked right before hand.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
