Old 08-09-2004, 09:40 AM   #1
biglou55
Question rearend pics please
No not that kind of rearend. I have a 69 3/4 ton and i would like to know if it is a dana or rockwell. it is kind of a round back cover. where would i find the gear ratio on it. the glove box decal is completly faded.all help would be greatly apreciated thank,s big lou.
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 08-09-2004, 11:57 AM   #2
53burb
53burb's Avatar
It sounds like you have an Eaton Rear. I also have a '69 3/4 ton. I believe the ratios are either 4.11 or 4.57...
Chris
53burb is offline   Reply With Quote
Old 08-09-2004, 11:58 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
It could also be a eaton from the round cover you describe..
FRENCHBLUE72 is offline   Reply With Quote
Old 08-09-2004, 12:08 PM   #4
JimKshortstep4x4
Smile
Does it look like any of these?
Jim
http://www.coloradok5.com/axleguide.shtml
Old 08-10-2004, 06:27 AM   #5
biglou55
Exclamation
Jim it does not look like any of them, dana or gm the filler hole is on the left hand side of the cover.when you are standing in the back of the truck.
Old 08-10-2004, 10:02 AM   #6
biglou55
T T T.
Old 08-10-2004, 10:12 AM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Try this website to i.d. your differential.
Differential Applications
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-10-2004, 02:03 PM   #8
Budweis
Geared for Collision
Budweis's Avatar
heres my eaton
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 08-10-2004, 02:56 PM   #9
biglou55
Talking
thank,s budweis That,s it round cover and all do you happen to know what ratios they used. or if it is on the case anywhere. thank,s biglou.
Old 08-10-2004, 03:13 PM   #10
Dean
Dean's Avatar
4.10 or 4.56 most likely. Ratio not on the case. You can either pull the back cover to read it or do the old spin the wheel and watch the driveshaft routine.
Dean is offline   Reply With Quote
Old 08-10-2004, 03:16 PM   #11
biglou55
Talking
Thank.s dean
Old 08-10-2004, 03:51 PM   #12
Bram
Broke
Bram's Avatar
Thumbs up
Dang Budweis that looks good! Do you have anymore pic's?
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 08-10-2004, 07:39 PM   #13
Budweis
Budweis's Avatar
thanks, heres a few more but its all in pieces still right now. working on that differential i got from you and wont be long and its going in. putting new u-joints, balljoints, seals , bearings, tie rod ends etc in it then gonna put it in. just got my corvette master cylinder and proportioning valve on it today as seen in pic. gonna be nice with 4 wheel disc cant wait.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 08-10-2004, 11:19 PM   #14
richardwilken
Budweis,
I Assume Your Truck Was Originally Drums All Around. Where Did The Discs Come From? Is There A Manufacturer Producing A Conversion Kit To Go To All Drums? Thanks
69 chevy 1/2 ton 2wd
72 GMC 1/2 ton 2wd
richardwilken is offline   Reply With Quote
Old 08-10-2004, 11:40 PM   #15
Budweis
Budweis's Avatar
yeah was 4 wheel drum, got the rear disc kit for the eaton at Blackbirds and for the front im using a 72 dana 44 with disc already on it i got from bram. all 4 wheels will use the same rotor calipers, and pads now which is also a bonus.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 08-11-2004, 12:50 AM   #16
drink2mny
drink2mny's Avatar
Thanks Budweis
Support The Board
drink2mny is offline   Reply With Quote
Old 08-11-2004, 09:08 AM   #17
Bram
Broke
Bram's Avatar
Talking
WOW! That looks really good. What size are those slicks you have on there?
Old 08-11-2004, 01:59 PM   #18
Budweis
Budweis's Avatar
thanks bram, tires are 35x14.50 on 16x10 rims. it's getting a 6" lift.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 08-11-2004, 03:51 PM   #19
Joesjunk
Joesjunk's Avatar
Here is a pic of where the #'s are stamped on an Eaton rear end. Not a very good pic, but it should help. If you find the letters, I can look it up for you.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 08-11-2004, 03:54 PM   #20
Joesjunk
Joesjunk's Avatar
Opps, forgot the pic,
Old 08-11-2004, 03:55 PM   #21
Joesjunk
Joesjunk's Avatar
That pic is the top of the 3rd member. Good luck!!
Old 08-14-2004, 03:39 PM   #22
biglou55
Talking
:p Joe the # on the rearend are MU0110G there is another # lower on the drivers side also 3883379 all help is apreciated biglou.
Old 08-15-2004, 11:42 PM   #23
Joesjunk
Joesjunk's Avatar
My book shows 1969 "MU" to be a 3:73 Locking axle for a C-20 or a
G-20? It also shows "MU" to be a 1967 C-30 5:14 Locker rear axle? Does that sound like what you have???
Old 08-16-2004, 08:35 AM   #24
biglou55
Wink
Joe i beleive it,s the mu 3-73 unit the rear hasn,t been changed acording to the p-o . is it worth anything seeing that it is a 3/4 ton locker. biglou 55 ( thank,s for your patience and help)
Old 08-16-2004, 12:01 PM   #25
Joesjunk
Joesjunk's Avatar
If your rear axle is a Eaton, I have never seen a 3:73 ratio in one of them. You might want to double check by pulling the cover and getting the numbers off the ring gear. You might also double check the "MU" code on the rear end again. My book shows codes for trucks and vans, and I am thinking the 3:73 was a van ratio??? Having the locker makes it worth alot more.
