Old 09-06-2004, 11:20 AM   #1
ChevyDude
Pic of Dynamat Xtreme and of the seats that will be going in!
As you can see I'm not done here and have quite a bit of work to do. I started putting in the Dynamat Xtreme sound deadening expensive stuff. It goes in fairly easily providing the surface is clean. I still have the passenger side to do. Also going to remove the gas tank for good, so all that area will receive the Dynamat Xtreme as well. New Black carpet will go in when the Dyanmat is done. Oh....also here is a pic of the 04' Yukon Denali seats that I "acquired" at a steal....lol. The other seat and center console is behind the truck.
Steering column goes to thew wayside in place of a Auto-tilt column...when I find the right one. Brake/clutch pedals are next to go...I have the Auto brake pedal waiting for it's install!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 09-06-2004, 01:19 PM   #2
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Nice score on the seats! I'd like t see a finished pic of the seats installed as that's what I had in mind or my 68
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 09-06-2004, 01:52 PM   #3
jay6891
Car Knocker
jay6891's Avatar
When I pulled my manual tranny out, all I did was remove the clutch linkage and slid the clutch pedal out of it holder. I don't believe there is any difference between auto and stick brake pedal. Believe there was a nut and washer holding it in the tube. Looks like great work though.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-06-2004, 04:54 PM   #4
ChevyDude
Well then I'll have a clutch/brake pedal assembly to sell!
Alex
