Old 09-14-2004, 08:26 PM   #1
Als454
PS Pump pictures?
Anyone have a picture of the BBC power steering pump that has the remote resevoir on it. I need one for my 454 and am considering altering a standard pump. I know how costly the factory ones are!
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 09-14-2004, 09:48 PM   #2
Rod
pic
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 09-15-2004, 06:59 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
-factory GM sticker still intact on the bracket in that picture Rod posted-
Tx Firefighter shakes his head in amazement.....
Tx Firefighter is offline   Reply With Quote
Old 09-15-2004, 09:32 AM   #4
Als454
Rod, Do you have a picture that I would be able to better see where and how the nipple for the hose is attached? Thanks
Old 09-15-2004, 10:47 AM   #5
flip66
flip66's Avatar
you can get a bracket from, I think its called, allen grove pullies for 60.00 to add just about any pump. I used one works great.
flip66 is offline   Reply With Quote
Old 09-15-2004, 10:56 AM   #6
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I sent some Pic of the PS setup to 1970 CST Short Wide awhile ago ,I deleteted them from my pic though , he may still have them .I can take some new ones later today .
Do you need anything else besides where the hoses attach. ?
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 09-15-2004, 11:36 AM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
Does this help?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-15-2004, 07:48 PM   #8
Als454
Bill72BB, I'm really interested in a close shot of where the hose connects and would also like to see where the remote resevoir is mounted.
Old 09-15-2004, 08:07 PM   #9
Tx Firefighter
I can get you whatever pctures you need off of my truck when I get off work in the morning.
The reservoir mounts on the left fender, right behind the little triangle core support to fender brace. There is a great diagram in the factory manual showing exactly where and how to drill the reservoir mounting holes on the fender. There are two different locations for the reservoir, depending on whether your truck has one or two batteries under the hood.
I used the manual diagram to drill the holes on my truck when I converted from manual steering 6 cylinder to power steering big block.
I'm on the Instagram- @Gearhead_Kevin
Old 09-15-2004, 08:13 PM   #10
rickh
The outlet is press fitted on.
Mine was leaking there and I was able to solder it with a propane torch and 50/50. I replaced the pump but when you do you only get the pump, not the housing. It is also press fitted on though easy to change. I could have ordered one with housing but the availability was unknown.
I would bet you could just get a brass heater hose outlet and solder it on. for the hose connection to the remote tank. Well now that I think about it, maybe not if you are using a small block pump. Not sure if the housing come off of them like the BB.
Rick H...
Rick H....
69 C10-CST
Wood bed floor full power
70 SWB 425hp HOTROD!
Full power
71 C20 Camper Special
402 full power, factory dual tanks with gauge switch. FOR SALE!
rickh is offline   Reply With Quote
Old 09-15-2004, 08:31 PM   #11
Bill72BB
Bill72BB's Avatar
Here is what I just took
BILL
Member DUF Club
Old 09-15-2004, 08:41 PM   #12
Rod
another from 69burb i believe he posted it at one time.
Old 09-15-2004, 08:57 PM   #13
Rod
Wes posted this one time.. its a 68 with an arm off the fender to put the resevoir outward some... Ive seen this set up too.. so its correct also.
Old 09-16-2004, 02:34 PM   #14
Als454
Thanks everyone! This is exactly what I was hoping for. Now to get busy.
