Old 09-22-2004, 06:22 AM   #1
69ChevyLB
Active Member
69ChevyLB's Avatar
Question Cleaning aluminum
What's the best way to clean aluminum parts such as alternators to make them look like new. Mine has that corroded look. Thanks.
69ChevyLB is offline   Reply With Quote
Old 09-22-2004, 06:34 AM   #2
shortymac83
hmm...
shortymac83's Avatar
not sure on the cast (lumpy) metal, but I know on smooth aluminum, gunk (to get most of the dirt off), then Nevr Dull or Brasso, then a coat of spray bomb clear will make it look like new.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 09-22-2004, 08:43 AM   #3
71-longbed
Its Magically Delicious
71-longbed's Avatar
i was wondering the exact same thing today ..... never dull does nothing to that "lumpy" aluminum of an alternator
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 09-22-2004, 10:34 AM   #4
Terry Peerson
Many years ago, I used to pull aluminum dump-trailers and then gasoline tankers. I used to buy this stuff from Fruehauf that I used to brighten them with. I don't know the concentration, but it was a combination of Hydroflouric Acid with some cleaners. Came in a gallon jug for about $ 10.00. It did a great job! After I got a real job, I used the stuff for the wire wheel covers on my wife's Caprice. The results were amazing! They came out perfectly clean and, best of all, the low pH kept the calcium from spotting the chrome (no water spots at all). They looked like I spent hours on them. Just spray and rinse.
Just BE CAREFUL WHAT YOU GET IT ON! And follow the dilution directions. It WILL bleach out the paint on engines (and fenders!). But it will make your A/C aluminum parts look like new.
Good Luck, and don't forget eye protection!
T
Terry Peerson is offline   Reply With Quote
Old 09-22-2004, 12:51 PM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I used mag wheel cleaner on a carb and an aluminum transmission case already. The kind you spray on and later rinse with water. It has some type of acid in it.
For parts like alternator cases though, a bead blast (or walnut shells) will make it look like new! The downside is you would have to take it all apart to do that.
Option #3 would be to hit it with a wire wheel on a drill, then spray it with aluminum paint such as Eastwoods Alumablast.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 09-22-2004, 01:56 PM   #6
Blue Beard
Blue Beard's Avatar
Try some of the new orange products, it really gets in and cleans.
No harshness, abrasiveness.....all liquid.
Sit and soak, soft brush to scrub.....rinse and clear seal with your choice of product.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 09-22-2004, 02:16 PM   #7
Dean
Dean's Avatar
I've had good results also with the non clear coated mag wheel cleaner. I think it is made by Eagle in a black spray bottle. It is wicked stuff so wear some eye protecting and I'd recommend gloves also.
Same stuff I keep my turbine wheels clean with. Everyone thinks I have painted them.
Dean is offline   Reply With Quote
Old 09-23-2004, 01:15 AM   #8
Iminocca
Easy-Off oven cleaner works well too. It etches the surface of the aluminum so you can't leave it on too long. You would have to disassemble an alternator to clean it this way however. Skin and eye protection required!
'71 C20 Camper Special
Iminocca is offline   Reply With Quote
Old 09-23-2004, 03:44 PM   #9
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
We've done it two ways. The shiniest results came from the stout mag wheel cleaner that bobs409 and Dean are talking about - Eagle was the brand, for non-coated wheels. We did take the case apart, but I guess you could put it on with a brush and avoid eating the internals. The problem was, after enough soak time to really clean the case, it was a very dull and dark gray color.
So then we took it over to the wire wheel, and it removed the dull gray and left a very bright aluminum finish. Went to a finer wheel, then used a mag wheel polish to seal. Looks pretty sharp! (its the one you can see in my avatar).
The other solution was taking it to the local starter/alternator shop, and they disassembled, put in new bearings & brushes, bead blasted the case, and even put a shiny new fan and pulley on, all for $30 including parts & labor! It looks factory-fresh.
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 09-23-2004, 11:41 PM   #10
Wootdog
Wootdog's Avatar
FLITZ. You can then use a high speed buffer and it will look better than new. You can make aluminum look like chrome if you polish it long enough. Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
