Old 09-24-2004, 03:02 AM   #1
Orange '71 GMC
Orange '71 GMC's Avatar
So how does the original A/C Center Vent work?
How is it held in place? I got my duct piece, gasket (which is just a piece of very thin foam), and the center vent, but I don't get it.
The center vent has to holes in the back, but they aren't threaded. Then the duct piece has a set of holes that line up in the back of it, but how does this go together?
Pardon the idiocy...I haven't been frequenting the board long/much, and there are some things I didn't learn back when I was doing my original build up.
Thanks in advance guys.
Orange '71 GMC
Orange '71 GMC is offline   Reply With Quote
Old 09-24-2004, 03:14 AM   #2
rage'nrat638
rage'nrat638's Avatar
the center chrome vent has two post that use the emblem twist nuts and the black duct that goes in the rear fit's over the post and then the nuts
you got to get to the rear to get them out......
rage'nrat638 is offline   Reply With Quote
Old 09-24-2004, 03:14 AM   #3
71swb4x4
71swb4x4's Avatar
I am pretty sure you need to put nuts on the studs.
That doesn't sound to good.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-24-2004, 03:15 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
There should be 2 threaded stud's attached to the chrome face of the vent.. The 2 stud's slide through the black plastic piece on the back side of the dash and are held together with 2 nut's...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-24-2004, 03:16 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Damit 2 second's to late... You beat me to it rage..
MEMBER #6377
Project "7DEUCE"
Old 09-24-2004, 03:35 AM   #6
rage'nrat638
hey were all here to help.....no problem.....i can only hope when i get a problem....somebody will help me...
Old 09-24-2004, 04:56 PM   #7
Orange '71 GMC
That's the kind of setup I was expecting, but that's not what is going on.
There are two (somewhat) "studs" on the back of the center vent. The problem is they aren't very long, and they have no thread whatsover on them.
I will take a pic and see if I can get some more clarification.
Orange '71 GMC
Old 09-24-2004, 05:20 PM   #8
rage'nrat638
Thumbs up
yes those studs....get the emblem nuts that self tap the threads into the plastic.....not much but it works....is this center vent new.....?????
if not they maybe broken off....
Old 09-24-2004, 09:27 PM   #9
neonlarry
neonlarry's Avatar
You must have gotten a new aftermarket vent. It has been my observation that the holes need to be tapped where the studs screw in (I just replaced mine) then the studs (I hope you keep your old ones other wise you will have to put the black piece that the vent hoses mount to on the vent and measure how long of a stud you need) screw in put throught dash put the plastic piece on from the back and put the nuts on.
P.S. my aftermarket vent was metal.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-25-2004, 02:25 AM   #10
pound41
The studs screw into the center vent back them out some to get the length you need then put the emblem nuts on the other side
pound41 is offline   Reply With Quote
Old 09-25-2004, 12:30 PM   #11
Orange '71 GMC
OK, I think I got it now guys.
My vent is new aftermarket. I am not sure if the studs are metal or plastic...I haven't really checked it out that good - it was chromed over, and I didn't tap on it or anything.
Either way, I know what to do now - thank you all.
Orange '71 GMC
