Old 10-17-2004, 01:23 AM   #1
crawdad
crawdad's Avatar
Radio opening - what to do?
The PO of my truck really screwed up the dash by cutting a larger opening for a radio. The holes for the knobs are gone. Looks like the opening was enlarged width wise, just beyond the holes for the knobs, but not very much in height. It had an old junky radio just shoved in the opening, not bolted in or anything. I know getting this back the way it was is more or less out of the question, but was wanting to get some ideas from you folks on how to fix this up so it looks a little more decent. Any ideas?
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 10-17-2004, 01:32 AM   #2
1969 GMC
1969 GMC's Avatar
you could put a new DIN sized head unit in the hole, or if you were extreme about restoring your truck you could cut a patch panel from a donor with a good radio hole, and weld it in to your dash.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-17-2004, 01:35 AM   #3
sdkid
You could have a piece of stainless or aluminum cut to fit the recess in the dash, and cut the radio opening in that. Although I havn't thought how to attach the stainless to the dash.
sdkid is offline   Reply With Quote
Old 10-17-2004, 01:44 AM   #4
71Longbed
Not Mine But A beauty
71Longbed's Avatar
Maybe theres a Radio delete or the other thing is just weld a patch or hell its already cut why not shove in a good head unit
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline   Reply With Quote
Old 10-17-2004, 10:16 AM   #5
ratrod67
ratrod67's Avatar
There's a guy who used a piece of diamond plate for a radio bezel. I remember it looking pretty good.
ratrod67 is offline   Reply With Quote
Old 10-17-2004, 10:49 AM   #6
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I have 2 couple center sections for sale if you want to weld in a new one.
Or, as suggested above, cut a piece of aluminum or stainless to go between the radio and dash metal.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-17-2004, 10:54 AM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
One of the board members (who is in the business of selling parts) was working on a patch panel to aid in the restoration of the dash. I forget who it is, which isn't too difficult at my age.
Member Nr. 2770
Old 10-17-2004, 11:13 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I just cut a patch pannel from one of the truck's at the junk yard and fixed mine...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-17-2004, 02:03 PM   #9
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Mine was cut fora CD player.I had the adapter that came in a CD install kit that had the regular radio mount in it.Adapter kit was for a 90's model Caravan I think.Anyways,it just clipped into the hole,and I mounted the radio in it.
I didn't do a more permanent fix cause I'm gonna install a CD player in time,so this worked fine in my case.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-17-2004, 02:44 PM   #10
67cst
i love summertime
67cst's Avatar
im going to have to cut some aluminum checkerplate for mine, the po raped it pretty good
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 10-17-2004, 07:51 PM   #11
Fred T
Cantankerous Geezer
Fred T's Avatar
I would cut a patch out of flat sheet, weld it in and convert to the modern system.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-17-2004, 08:38 PM   #12
botboy
On my '72 PO did the same things....except it wasn't quite straight
I used some flat sheet metal off of a junk hood and smoothed it out...was going to re-cut for a CD deck but never got around to it...
botboy is offline   Reply With Quote
Old 10-17-2004, 10:12 PM   #13
longnlow72
longnlow72's Avatar
i cut a piece of plexi glass for a temporary fix untill i painted the truck, then i painted it silver like the trim ring on my cd player
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 10-17-2004, 10:36 PM   #14
mdazb
mdazb's Avatar
How is the deck mounted? This is exactley what I want to do with my 72 c10
mdazb is offline   Reply With Quote
Old 10-17-2004, 10:46 PM   #15
BIG ORANGE
BIG ORANGE's Avatar
I would take another dash center and weld it in just be sure you cover the glass if you still have it in the truck!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 10-18-2004, 07:00 AM   #16
vtblazer
vtblazer's Avatar
Fix It
As stated above several times, fix it by using another dash as a repair panel.
All depends on what your looking for as the end results though, factory/modern...
vtblazer is offline   Reply With Quote
Old 10-18-2004, 08:17 PM   #17
crawdad
crawdad's Avatar
Appreciate all the help and your ideas and pictures folks. I've got several good ideas I can run with now. Again, thanks.
