Custom VDO gauge AND Grant steering wheel with horn and column adapter.
Custom VDO gauge cluster Fits 1973 to 1987 truck/sub/blazer dash panels This set up was built by removing the gauges from a standard gauge cluster and replacing them with standard VDO gauges using a VDO gauge mounting plate. Gauges include, water temp, fuel, volts, oil pressure, speedo and tach. The speedo and water temp gauge are mechanical. This gauge set is used, but with a little effort you can easily adapt this to your dash. Black spoke Grant steering wheel with adapter. This is new wheel, mounted but never used. Adapter fits 1973 through 1987 Chevy Truck steering colums, tilt or standard. Buyer pays shipping. I don't hit this board too often, too much to do, please email me at videos@bright.net if you are interested. Thanks |
