Old 11-03-2004, 04:02 PM   #1
meathead95
computer illiterate
meathead95's Avatar
fuel pump?
what psi does a stock fuel pump on a 1977 454 put out?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-03-2004, 05:00 PM   #2
Burnsman
Chevy Freak
Burnsman's Avatar
fuel pump
I was thinking somewhere in the 5 psi range.
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
Old 11-03-2004, 05:54 PM   #3
crazy longhorn
Fabricate till you "puke"
Yup, probably in the 5-6 psi range.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-04-2004, 02:57 PM   #4
meathead95
computer illiterate
meathead95's Avatar
so it should be good with an edelbrock carb without a regulator?
72 2wd blazer
72 swb 4x4
Old 11-04-2004, 03:09 PM   #5
Burnsman
Chevy Freak
Burnsman's Avatar
fuel pump
Yep. Stock pump will be fine without a regulator.
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
