Old 11-05-2004, 08:47 AM   #1
72longbed
72longbed's Avatar
Question 4x4 Question
I'm sure many of you guys know the answer to this: Can the power steering box and column from a 2wd C-20 be used on a 4x4 K-20 frame??
Thanks for your guidance,
72longbed
72longbed is offline   Reply With Quote
Old 11-05-2004, 08:50 AM   #2
64fleetside
no
64fleetside is offline   Reply With Quote
Old 11-05-2004, 09:03 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The column yes but not the gear box unless you do a cross over steering set up. But then you'd need to have the pass side steering knuckle modified, and a new drag link made. Truck would also have to be lifted.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-05-2004, 12:30 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Lift should be over 6" for cross-over too.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-05-2004, 12:47 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Also forgot would need a diferent pitman arm.
Old 11-06-2004, 01:38 AM   #6
72longbed
72longbed's Avatar
OK,
so what power steering box is in a 'factory' K-20 with power steering? And what if the 4x4 is manual steering and you want to convert it to power?
Thanks again,
72longbed
Old 11-06-2004, 07:44 AM   #7
GM72K10
Next!
GM72K10's Avatar
72 Longbed, aren't you the one who got the trailing arm from me? I Have one of those PS boxes, good for a core at least.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 11-06-2004, 06:56 PM   #8
Longhorn4x4
I just swapped the pitman arm on mine.
Longhorn4x4 is offline   Reply With Quote
Old 11-06-2004, 11:05 PM   #9
72longbed
72longbed's Avatar
Longhorn4x4,
are the power steering boxes the same, (2wd vs. 4wd), with just a different pitman arm?
Thanks,
72longbed
Old 11-07-2004, 02:43 AM   #10
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
not a pro, but i think 4x4s are on the inside of the frame, and 2wd are on the outside. but when i put ps on my truck it had to be 71-87 2wd 1/2 ton period
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-07-2004, 04:46 AM   #11
breeh
Recovering 67-72 Addict
breeh's Avatar
It is a different box and a different pitman arm. You will have to find a donor 4x4, buy one off this board. or purchase a new one. I put a box from AGR on mine.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 11-07-2004, 09:21 AM   #12
GM72K10
Next!
GM72K10's Avatar
69-72 K-5,K10,K20 ps boxes will all interchange, and they are different than their 2wd counterpart.
86 K30 CUCV M1028A1
Old 11-07-2004, 02:56 PM   #13
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
4x4 gear boxes are on the outside of the frame also.
Old 11-07-2004, 06:31 PM   #14
72longbed
72longbed's Avatar
Thumbs up
Thanks GM72K10 and everybody else, I finally understand what I need now. I've been kicking around the idea of finding a 71 or 72 4x4 rolling chassis and hanging all of my sheet metal and drive train on it. I want to be prepared if I can only find a 'manual steering' chassis as a donor. I'll be selling my 2wd rolling chassis on this board or E-Bay if anybody is interested. Now that I've replaced all the wear parts from front to back it's time to sell it, right...?
Thanks again,
72longbed
(anybody know of any good 4x4 rolling chassis around PA, prefer 3/4 ton?)
Let me know.
