Old 12-17-2004, 10:58 AM   #1
Vince Putt
Hippy
are replacement mounts that are riveted to frame available
Looking over the mess I have of a stripped frame, I was wondering are the radiator core support, cab supports, and bed supports that are factory riveted to the frame available from the aftermarket? Some of mine look pretty nasty, with oblong holes insted of round.
Vince Putt is offline   Reply With Quote
Old 12-17-2004, 01:37 PM   #2
JimKshortstep4x4
Smile
You can get used ones usually but I have not seen new ones.
We weld on large washers with the right size holes. Makes a pretty good fix.
Jim
Old 12-17-2004, 07:00 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I had to put all new brackets on my frame for my bed. PO before the PO had removed them for a flat bed. Got all 6 from board members, attached them with 3/8" grade 8 hardware. Going strong for 6 months now.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-17-2004, 07:15 PM   #4
MOTHERTRUCKERS
I have good used in stock plus the rivets.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
