Old 12-13-2004, 11:37 AM   #1
4x4ollie
need auto / transfer for 70 k-10
looking for parts to change 4-speed 70 k10 to auto ( 350 )
4x4ollie is offline   Reply With Quote
Old 12-13-2004, 01:16 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
location is very important on the big and heavy things like this, where you at? I have the stuff you are looking for but unless you are close shipping is a killer.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-13-2004, 03:34 PM   #3
ryanroo
ryanroo's Avatar
if you are interested, i may need some of the parts you are taking off. let me know if you want to sell anything. thanks
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-13-2004, 07:10 PM   #4
4x4ollie
tennessee maybe still interested. what all do you have ?
Old 12-13-2004, 07:50 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Talking
WHERE EXACTLY, AND WELCOME 2 THE BOARD FROM WEST 10-UH-C
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-13-2004, 10:34 PM   #6
4x4ollie
piney flats about 10 to 15 minutes on 11e southwest of bristol speedway
or in other words in the hills
Old 12-13-2004, 11:06 PM   #7
chucks70
Never thought about getting rid of the parts but I have most everything you would need, auto trans still connected to the t-case, cross member, mount for the t case and I think I still have the auto linkages. The drive shaft I have would be for a Blazer. Flywheel is still on the 307 that was hooked to it. I live in Northern Panhandle of WV.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 12-13-2004, 11:43 PM   #8
mrein3
mrein3's Avatar
4x4ollie:
You already have the cross member and driveshafts you need for this swap...
They are currently installed in your truck!
You need the th350, adapter, and t-case. You also need an auto steering column and the shifter linkage from the column to the tranny.
Try to get the transfer case shifter with the used parts. I did not and then I had to get a new shifter bolt from the dealer. They were different on the two NP205s I had. However the shifter was the same.
Closely inspect any adapter you buy used for cracks. I've never seen a used one that wasn't cracked. I would also change the grease seals in the adapter and purchase and install a new drive sleeve while you have it apart. The sleeve and seals are what keep tranny fluid in the tranny and gear oil in the transfer case.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-20-2004, 10:47 PM   #9
4x4ollie
thanks mrein3
sorry to be awhile getting back. mother-in law in hospital. i believe i solved my problem i bought a complete truck.
