Old 01-05-2005, 08:00 PM   #1
Benrs86
Benrs86's Avatar
fast idle problem 78 chevy 350 quadrajet
hey i neeeeed some help. i just put this 350 in my granpas s10 and i cant get it tuned right. i put a rebuilt quadrajet on it and it has hei. the vacuum lines have one of those thermo deals on the thermostat housing. i routed my hoses around that. so i have one hose to the transmission, one to the cruise, one to the booster, and one to the distrbuter. i timed it the best i could so it is at really close to 12 before tdc at about 800 rpm. i cant keep the engine idling at 800 though. i have to keep revving it otherwise it will die. to get it to idle good it is at about 1200 rpm. what do i adjust? do i need the vacuum thing? should i time it different? is there a step by step tuning instruction thing somewhere i could read? THANKS FOR THE HELP, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
