Old 01-08-2005, 08:10 PM   #1
margay
power antenna question
have a 72 C10 i would like to put a power antenna on it. Has anyone on here done this if so what did you use for antenna and was there a lot of modifcations you had to do to make it fit.
margay is offline   Reply With Quote
Old 01-08-2005, 08:45 PM   #2
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
Classic heartbeat did this on there 67 panel project.Check out there website,and click on the panel project link.
mblackburnjr is offline   Reply With Quote
Old 01-08-2005, 08:50 PM   #3
LONGHAIR
Most of the time I use Cadillac antennas. Specifically the early 80s model Coupe or Sedan DeVille. Mainly bacause of availability. These are a front fender mount and have fairly small motor/case.
There are many universal kits though. You need a radio that has the wire to trigger it or you have to run a seperate switch for it. You need to make some kind of strap to the lower mounting point to keep it steady. Other than that it's no biggie.
LONGHAIR is offline   Reply With Quote
