king $h!t
i am geting ready to put my lift on win this thought came past my mind my axle isnt going to set at the right angel any more i heard of axle shims but most people use the on lowerd car and such
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s |
I have used them ,on lowered ,or modified suspensions. Raising can do the same thing. Shims should be available at your local spring shop,& they can supply you with a spring center bolt that has a longer locator pin if need. Good luck.....69 longhorn.
http://community.webshots.com/user/hotrodhorn |
![]() Join Date: Feb 2000
May not be much of an issue, depends on how high you are going. Usually you don't have a problem with a 4" lift, probably an issue with a 6" or higher.
------------------ 1969 C20 4x4 with roughly 6" lift and 35's residing near Rose Hill, Kansas Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
king $h!t
well the lift is six inch and i have a three inch body lift
