Old 02-14-2005, 05:47 PM   #1
67chevemall
67chevemall's Avatar
Question upper control arm?
So you want to save your upper control arm bushings and the rest!
Do you grind the rusted nut and bolt going through the frame or
can you just losen the big a55 nuts on either side on the
upper control arm bushings?
How do these come off?
I'm just about to pop the ball joint loose and take the spring out
but I am wondering what is next.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-14-2005, 06:12 PM   #2
low 84
low 84's Avatar
so what exactly are you trying to do? if your trying to get the upper control arm off, once you get the spring out, just take the two nuts off that go on the studs that go to your frame, same studs that hold your alignment shims
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-15-2005, 10:11 AM   #3
67chevemall
I don't really need the control arm but want to save the crazy looking part with the bushings in it. Are these re-useable or am I wasting my time. They were new about 4 months ago along with the ball joints.
Any help would be great!
Old 02-15-2005, 10:30 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
They are re-usable. You will have to press them out and risk destroying the bushing though....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-15-2005, 05:41 PM   #5
67chevemall
If I take the whole control arm off, I could re use the whole thing I guess!
Save wrecking anything. I can't believe with all the bolts on this truck
only 2 hold the upper control arm on!
