Old 03-05-2005, 12:48 AM   #1
Elsie72
Chinook Arch
Elsie72's Avatar
Removing lower track bar mount?
I removed the track bar from the truck, and undid the nut on the front side of the diff housing, but the stud that remains doesn't seem to want to budge. Do I need to use a puller to get this out, or just get a bigger hammer?
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
Old 03-05-2005, 08:00 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Give it a little twist with a pipe wrench and it will come right loose. I had to do that myself a few times.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-05-2005, 11:07 AM   #3
Elsie72
Chinook Arch
Elsie72's Avatar
Thank-you. I'll give that a try.
Elsie's truck
ECE drop 3.5/5
Old 03-05-2005, 04:55 PM   #4
XXL
Seņor Member
XXL's Avatar
I'd avoid the hammer if possible. I've seen that whole cast loop break off.
XXL is offline   Reply With Quote
Old 03-06-2005, 09:18 PM   #5
Elsie72
Chinook Arch
Elsie72's Avatar
Good call. I didn't consider that, but it's definitely something to look out for.
Elsie's truck
ECE drop 3.5/5
Old 03-06-2005, 10:16 PM   #6
Elsie72
Chinook Arch
Elsie72's Avatar
Well, a little propane persuasion, and an 18" pipe wrench, and out it came!
Thanks TX Firefighter, and XXL
Elsie's truck
ECE drop 3.5/5
