Old 03-13-2005, 03:46 PM   #1
67stepside
67stepside's Avatar
Question Tach Wiring
Hey I have a ? I got a tach dash at the Louisville swap meet yesterday. Where does the wiring harness go to? The one i got has been cut so I only have the end on the tach. Thanks
67stepside is offline   Reply With Quote
Old 03-13-2005, 05:06 PM   #2
jhow66
jhow66's Avatar
Give me the wire color.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-13-2005, 07:54 PM   #3
JimKshortstep4x4
Smile
The factory harness had a pink wire for the 12 volt terminal and it plugged into the fuse panel in the "Ignition Unfused" location. The other wire was brown and it went to the negative side of the ignition coil. If you have HEI then it should plug into the terminal on the coil marked "Tach".
The tach gets its ground through the instrument housing.
Jim
Old 03-13-2005, 07:58 PM   #4
67stepside
67stepside's Avatar
one is brown and one is pink. on the back of the tach it is labeled "coil" and "12 volt". the brown is on the coil side and pink is 12 volt. is that all i need to do is wire it to the coil and a power source?
Old 03-13-2005, 08:16 PM   #5
jamie72
jamie72's Avatar
if its a factory tach, coil wire go`s to the coils or hei, and the other go`s to your fusebox on a keyed hot plug in... so where did you find that? i missed it, i was there friday and saturday....but did frind some good deals
good luck with the tach.
jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 03-13-2005, 08:37 PM   #6
67stepside
67stepside's Avatar
Just as i came out of the little back room I turned right. On the corner was a guy with a lot of 67-72 truck parts, had a 67-68 white grille standing up against wall. Any way right next to him was a guy that had one sitting on his table, I think he also had an old maybe 65 Impala convertible for sale, pretty rough. I asked him how much and he said $200, I walked away and came back in about 5 min. and offered him $150, got it bought for $160. Hope it works!!
Old 03-13-2005, 09:30 PM   #7
jamie72
jamie72's Avatar
yea i know the guy his name is bill i think, i was in the other small buliding, sounds like a good deal, good luck with it.
jamie
jamie72
member #807
www.antlertalk.com
Old 03-13-2005, 10:32 PM   #8
67stepside
67stepside's Avatar
Thanks for the info. John
