another speedo question
I have a 88 burb - just put axles under it . the gear ratio is diff. also went to 33" tires, do I have an electronic speedo? how do I calibrate it?
72 c-10 81 c-30 67 c-10 just sittin in the woods) 70 C-10 " " " " to compleete frames 67, 70 - in woods 2002 toyota tundra. 12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker |
check out these 3 links... you need to replace one or both of the gears... one is easy... the other you have to take the driveshaft off and the end of the tranny cover off.
you don't have electronic... it's mechanical. http://www.tciauto.com/tech_info/speedo_gears.htm http://www.transmissioncenter.net/sp...n_______va.htm http://www.thirdgen.org/newdesign/tech/speedogear.shtml |
