Old 04-02-2005, 02:55 AM   #1
skokie
skokie's Avatar
180 vs 195 Thermostat
I saw a thread on this a few months ago and I did a search but it didnt find anything under thermostat, 195 or 180. So here is the question. For a daily driver is a 180 or a 195 better? Engine is a crate 350.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 04-02-2005, 03:25 AM   #2
70short/step
70short/step's Avatar
For the crate 350 in our trucks I would run the 180. The 195 is more for the engine of today with emission control devices and computer controls.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 04-02-2005, 07:01 AM   #3
JimKshortstep4x4
Talking
I would go with the 180 degree. I run a 195 degree in my plow truck because it is driven in the winter and the higher temperature is nice for heating and making sure the engine does not collect moisture. We run 180 degree stats in the other trucks/cars that are not driven in the winter.
Jim
Old 04-02-2005, 08:30 AM   #4
180 does the job.
Old 04-02-2005, 01:26 PM   #5
67shortie
Green club
67shortie's Avatar
The late great Smokey Eunick one stated that the 180* wanter temp in a small block was the most ideal. I run 180's in all of my older engines.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 04-02-2005, 01:33 PM   #6
Zonaman
Zonaman's Avatar
I've got a 160 in mine. Is that unusual?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 04-02-2005, 02:02 PM   #7
ddsmith
Glowing since 1978
ddsmith's Avatar
180 should be what is installed. I think the reason they sell 160 is that when people's cooling system isn't working very well they figure putting a 160 thermostat in will fix there problem. The engine likes 180 because that allows the oil to maintain the best temperature from a lubrication/cleaning stand point. The change to 195 was driven by lower emissions. That doesn't mean that is the best for the oil it's just a compromise. I would run 180 in everything. It gives you a cushion from an overheating condition of 15 more degrees. As long as you don't have a problem passing emissions testing if you have them.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 04-02-2005, 02:05 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
160 thermostat
I agree Skokie 180 cool (pun intended)
That should be fine for Pheonix and the hot weather. The thing to be careful of is having the t-stat open too soon and letting the coolant circulate through the radiator too fast for it to cool down. This happened to me once when I ran with no thermostat in traffic and the car almost overheated before I coul get out of the heavy traffic and speed up.
Vettevet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-02-2005, 09:25 PM   #9
Z28Owner
Z28Owner's Avatar
I had a 180 in mine and when I went to fix a leak at my thermostat housing, I figured I try a 195 cause it would run 185 all the time. I put the 195 in and now it opens at 195 the cools back down to 185 and opens back up at 195. Guess it getting too cool. So I am gonna go back to a 180.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 04-02-2005, 10:04 PM   #10
86k10
I'm going to go against the grain and say run 195 all year long no matter where you are. If your cooling system is in proper order you can do that even in the hottest weather. And keep in mind the warmer an engine runs to a point the less they wear and the more efficient they are and that's easy to understand since all carbureted engines idle faster when they are hot then when they are cold. But 180 is not enough so if you want to get your best fuel mileage then keep that temp up around 200.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 04-02-2005, 10:08 PM   #11
69 longhorn
My vote is for the 180, with a stock fan setup. I run a 160 in my longhorn. but she runs dual elct fans, with a Painless fan control (on 185/ off 170). the sb pretty much runs tween 170-185, idling in traffic, or out on the open road, & the fans switch on/off like they should. with a 180 stat, she never overheated, but the fans ran nonstop! 69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-02-2005, 11:04 PM   #12
71-longbed
Its Magically Delicious
71-longbed's Avatar
i just switch from a 180 to a 195 ... i like the 195 better ... My engine runs smoother with the 195 .. i make lots of short trips (under 5 miles) ...Works Great for me ...
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 04-03-2005, 01:54 AM   #13
skokie
skokie's Avatar
Thanks for all the info here guys. I currently have a 180 in there now but I am about to put in new top and bottom radiator hoses and thats why I asked. WIth the 180 in there now the temp gets to 190-195 max. I think I will stick with the 180. Thanks again guys.
68 build thread
