Old 04-06-2005, 03:36 PM   #1
bringit
Front lift shakels
Has anyone used them, my dad has them on his truck and it gave him 3" of lift. But I think they were home made by the previous owner. I only need that much to run my tires until I can afford the springs.
85 chevy K10 350 crate, headman headers, street avenger carb, accel distrib , rebuilt 700r4, on 33" Super Swamper TSL's, 4 inch Pro Comp lift, shocks, and steel braided brake lines.
bringit is offline   Reply With Quote
Old 04-06-2005, 05:03 PM   #2
1969K10
1969K10's Avatar
The only experience I have with them, is a guy here at work used lift shackles for his Ram... It rotated the yoke for the front driveshaft too far down, and it hits everytime the driveshaft rotates... I guess just be careful of that if you go this route. He's had them on for 6 months now, and no problems other than that...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-06-2005, 06:03 PM   #3
bringit
Ill probly just do it right with springs, but the hangers are tempting
Old 04-06-2005, 09:20 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Not only does it kill the pinion angle, it also negates the caster and will cause the truck to wander.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-06-2005, 09:33 PM   #5
1FaastC10
1FaastC10's Avatar
if the truck is set up to run longer shackles, its fine. my truck had 7.25" ctr to ctr shackles on it, with no issues, but i was running springs 4-5" longer than stock, and a modified mounting point for the shackles.
1FaastC10 is offline   Reply With Quote
