Old 05-06-2005, 07:24 PM   #1
71swb4x4
71swb4x4's Avatar
68 Cab $175 South Dakota, with title
Here is a 68 cab that needs some work. I do have the title for it.
The cab has had rockers and cab corners replaced. The gas hole has been filled. The lower parts of the inside and the bottom of the cab have been coated with a material that look slike bed liner.
I used a magent on the cab and found two spots in the back that have some filler that is a bit deep. There are a couple of welds that need to be filled. One of the back corners has been bent.
I have a lot of pictures, let me know if you want to see more.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
