Old 04-21-2005, 08:02 PM   #1
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
Wiring Question 101....HELP
Ok.this is my stubby rear tail light wiring harness from the flat-bed dually...........Had a bunch of tangled wires when I got it...Am a little stumped..Yes I can probably look at the manual but maybe some-one can just give me some simple instructions..Thanks..........Black and brown wires are hot...Then there is the yellow,green,and light green..I got the tail lights to work and the brake lights but not the turn signals???Thanks in advance for any advice............
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 04-21-2005, 08:36 PM   #2
john
member #16
john's Avatar
Here you go. John
http://www.geocities.com/chevroletc1070/wiringdias.html
john is offline   Reply With Quote
Old 04-21-2005, 08:46 PM   #3
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
Thanks...John...I think I can figure it out with this diagram...........
70-C/30 DUALLY
Old 04-21-2005, 10:39 PM   #4
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
OK.............I may have spoken to soon..What if both turn signals are flashing ?????????Must have one wire in wrong location????????
70-C/30 DUALLY
Old 04-22-2005, 02:20 AM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Well according to the schematic
-one brown to each turn siganl.
-Dark green to the passenger light.
-yellow to the drivers light.
-light green goes to the reverse lights.
Most likely the brown is power with the lights on,when the brakes are hit and when the 4 way flashers are on.
The yellow and dark green are most likely power when the turn signals are activated.
I"ll go out there and say that the yellow and dark green have power when the 4 way flashers are on as well.
I did trace all this out a long time ago but have since forgotten.If I'm wrong I'm sure someone will chime in.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-22-2005, 01:46 PM   #6
fatfords
fatfords's Avatar
The wiring diagram for a 72 lists the following:
The brown wire is for tail lights (dim on dual filament), tag light and side marker lights, if you have them.
The yellow wire is for drivers side stop/turn (bright on dual filament)
The green wire is for passenger side stop/turn (bright on dual filament)
The light green wire is for back-up lights.
Good Luck!
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 04-22-2005, 10:35 PM   #7
rmrtndl
Hey ya'll, Watch this!
rmrtndl's Avatar
My neighbor had a problem where both turn signals flashed at the same time. It turned out his ground wire was not grounded.
Rick M.
72 GMC SWB Fleetside
25 Chevrolet Superior Series Truck
95 Mazda Miata
06 Dodge Charger RT
http://ram92.ods.org/blog.html
rmrtndl is offline   Reply With Quote
