Old 05-16-2005, 02:45 PM   #1
raa
Removing Bed/Cab
A while back I remember seeing some posts with pictures of a bed and cab being removed with an engine hoist. Haven't been able to locate them again. Does anyone have any of these? I remember something about cement blocks being needed in the cab to hold it straight?
raa is offline   Reply With Quote
Old 05-16-2005, 03:34 PM   #2
krue
Designated A-hole!
krue's Avatar
I know the cab is front heavy, when I pulled mine (with a chainfall hanging from a tree limb) I had to put the strap all the way forward on the door windows and it still sagged a little to the front.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-16-2005, 06:24 PM   #3
cadiac
Removing a cab -Use the cab mount holes and rig a 4 way with 2 chains, -one at rear and one at front. 3/8" bolts front -5/16" at rear because the mount bolt cage nuts if they didn't rip loose are 3/8" -hence the 5/16" will pass through the nuts. (long obviously with BIG flat washers -grade 5 or "8" preferred! -Nothing LESS!!!) You'll have to play a bit to get it to come up reasonably straight. Have brake booster off and would be good for a/c stuff off front of firewall but not neccesary. I do it alone but would be good especially if its windy to have a helper. Roll window down and stick cherry picker in through it. You'll have to experiment with lengths a bit. "No Bent Gutters"!
cadiac is offline   Reply With Quote
Old 05-16-2005, 08:14 PM   #4
Johnny Outdoors
SOON TO BE A STEP SIDE
Johnny Outdoors's Avatar
here is another option
a 6x6 v'd out on each end to hold the strap from binding/slipping.
a knotch on each end of the 6x6 for the door lip to set in
a tractor
a strap
67 CHEVY LONGBED----- BEST 51 DOLLARS EVER SPENT ON EBAY!
4.3 LITER INJECTED MOTOR WITH 5 SPEED GOING IN SOON
Johnny Outdoors is offline   Reply With Quote
Old 05-16-2005, 10:36 PM   #5
70 longbed
Maybe not what you are looking for, but a 4x4 through the cab, the hoist goes under the 4x and it will lift straight up. This is not real stable, and you will need to set it down as soon as you can. I lifted mine up, rolled the hoist back and set the cab on some blocks by myself. Had a couple of friends help me when it came to putting it back on.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 05-17-2005, 12:25 AM   #6
wanted
Kind of hard to see with all the clutter. Engine hoist mast is inside cab lifting on the roof, it balances quite well. This was a junk cab. On my good one I used 2 2x12's screwed together run between the door openings, Also I had some 1 inch rubber pads where the wood touched the cab. Really simple, I had no problems, just take out all the extra weight. The bed is tricky, my hoist would not reach to the center of the bed.
wanted is offline   Reply With Quote
Old 05-17-2005, 12:35 AM   #7
longhorn71
longhorn71's Avatar
i used a couple chains that were hook in the stake pocket (all 4 coners)and lifted the bed for the center with a chain hoist
longhorn71 is offline   Reply With Quote
Old 05-17-2005, 07:13 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
I made this "jig for 2 purposes. one was I could jack up framew & bolt this to cab. then lower frame & roll cab off back of frame with rear tires removed. the other is for doing the cab repairs.
if needed I can take more detailed pics & get measurements.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-17-2005, 07:22 AM   #9
Joe67
67 is sold
a tractor
a strap
Pretty much the same here except I had to use a cherry picker, no tractor here in the 'burbs
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 05-17-2005, 09:32 AM   #10
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Like the jig 68c15. Think I can figure out the dims. What size square stock is that?
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 05-17-2005, 10:04 AM   #11
rodstored-72
chevy truck fan
rodstored-72's Avatar
this is a cool thread!! i am getting ready to lift my cab off as well. i am wondering if you have about 6-8 friends can the cab be lifted off (emptied -w/ doors) by hand & then set on some 4x4 blocks?? i am going to paint the frame and then put cab back on in the same weekend. i would appreciate any suggestions or ideas!
thanks!! : rodstored-72
rodstored-72 is online now   Reply With Quote
Old 05-17-2005, 10:27 AM   #12
greasemonkey
greasemonkey's Avatar
6-8 would be more than enough.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 05-17-2005, 11:58 AM   #13
BigSky71
LAIDOUT
BigSky71's Avatar
To reasonably healthy adult males can walk around with the cab if it stripped clean. And I have seen two guys carry a short bed around too, minus tailgate, actually it was yesterday. We carried the cab inside and set it on the cab dolly it fit perfect.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 05-17-2005, 09:27 PM   #14
68C15
blood type; Retumbo
68C15's Avatar
the base is 2x2. the lower part of the top is 1x1. the top of top is 1 1/4 square. then all bracing is 1x1. I used spare striker plates for the rear. I wish I had a spare set of hinges for the "A" pillars. I made the framework sit away from the body enough to clear the frame & also give working room to replace rockers etc.
my next addition is to install some rear wheel hubs from a Caravan so I can tow it around.
Old 05-17-2005, 11:12 PM   #15
Solver
Solver's Avatar
I have these pics of my setup
I did use concrete blocks to level out the weight
It has an adapter on top of the hoist
I posted specs and dimensions a while back
works nice and only takes 1 person to operate
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 05-18-2005, 08:33 AM   #16
raa
Thanks everyone...lots of good ideas. Solver....that was what I was looking for!
Old 05-18-2005, 01:42 PM   #17
67chevemall
67chevemall's Avatar
Great pics! Anybody with a pic of the bed about to come off?
I guess you need to get the picker to the middle of the bed?
67chevemall is offline   Reply With Quote
Old 05-18-2005, 02:06 PM   #18
cadiac
Solver -Did you make or buy the adapter you use on top of the cherry picker? I'd thought of something like that.
Old 05-18-2005, 11:30 PM   #19
Solver
Solver's Avatar
I had posted dimensions a few months earlier in a post with dimensions
Hopefully here is the link I hope it helps
http://67-72chevytrucks.com/vboard/s....php3?t=113397
Old 05-19-2005, 07:47 AM   #20
arkracing
Weekend Warrior
If you use the 4 cab mount holes and bolt chains through them it is easier to manipulate the angle of the cab when hoisting. just make sure that you use 2 chains - 1 for the front cab mount holes and one for the rear cab mount holes....then hook onto the chains further toward the front and use a screw driver of bolt to keep the chain from sliding through the hook on your hoist. - just a thought.
Solver's looks pretty good.
Wanted's looks kinda scare by the way he describes - but might not be.
the main problem with the hoist way of doing it is when you go to move it it is going to swing all over the place on you (especially if you use a chain or straps)
Solver's probably didn't move cause hes got it set up so there is no pivot point on the hoist (good engineering!!)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
